Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
  #11 (permalink)
Old 06-18-2009, 08:32 PM
Variable556 Variable556 is offline
Originally Posted by rjwareagle View Post
I got in today and noticed that the trans and water temp lights are out. the needle is still lit and the gauges work, but the lights in the back ground are out. what do to? Is this a common thing? how hard is it to fix?
The EXACT damn thing just happened to me this evening. Any updates you can share??? How involved is it to take the dash apart to get at the bulbs? I hope you got your bulb situation figured out so I can pick your brain!!!
  #12 (permalink)
Old 06-18-2009, 08:39 PM
peterbilt600x peterbilt600x is offline
Send a message via AIM to peterbilt600x
me 3 mine have been out for awhile
  #13 (permalink)
Old 07-15-2009, 08:08 PM
RacingStangs RacingStangs is offline
If you pull your dash apart and take out the instrument cluster you will see small black things sticking out of the back. Wish I had pics, but they're round with a flat bar thing sticking out. Just turn them counter clockwise and they come right out. There should be a bulb in there like a 194 or something. There will be a number on the bulb. Pull the bulb out of the black handle, put a new one in, and just put it back in the cluster and turn it clockwise until it stops.
  #14 (permalink)
Old 07-15-2009, 08:11 PM
Strokeorcroak Strokeorcroak is offline
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
The bulbs in mine are white.. I have replaced a few of them and recently a few more went out (different ones) so i get to do it again. I had to drop the steering column, pull the dash out and the bulbs are back in there... its prolly like an hr worth of work
  #15 (permalink)
Old 07-15-2009, 08:40 PM
rjwareagle rjwareagle is offline
mine went pretty easy, now im thinking about replacing them with leds...
