Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
  #51 (permalink)
Old 09-18-2009, 03:56 PM
foglybon foglybon is offline
I have 1 hooked to the high idle feature. It was that way when I bought it. I looked up behind the switches to find the end to # 2 to hook up power to my sirius radio. I found the wires up behind the fuse box. One side goes to the orange wire which I assume is the positive side where is the other wire connected to?
  #52 (permalink)
Old 10-03-2009, 05:26 AM
bondsman bondsman is offline
The ends are under the dash near the fuse block.
  #53 (permalink)
Old 10-19-2009, 08:24 AM
rodmodder rodmodder is offline
I was planning on using #4 for the high idle mod, and #3 for the remote turn on heading to the subwoofer amplifier. I'm still running the stock head unit.
  #54 (permalink)
Old 10-19-2009, 09:19 AM
ruystyb265 ruystyb265 is offline
I have an '06. My owners manual says the wires for the switched dead end in a second fuse box behing the glove compartment. Havent looked yet though. I like the high idle idea. Just would question how good it is for the truck to start up in cold weather and then jump right up to a high idle. I like it for extended idle time once its warm though.
  #55 (permalink)
Old 10-19-2009, 09:25 AM
Snake Snake is offline
Originally Posted by doubledrop View Post
i use one for the compressor to my train horns/tank. i use another one to 'switch' to my train horns. I use a realy so can stll use factory horn, then flip up 4th switch then I use my steering wheel horn button to blast my train horns. I didn't want my compressor running all the time since not always using it thus why i also put it on one of my upfitters.
Great minds think alike!
#3 is the train horn on/off switch
#4 turns the compressor off, regardless of what the pressure switch is telling it to do
And #1 is for my back up lights.
After a lot of thinking, I'm going to use #2 for the high idle mod. And before you flame, yes, I know that #2 would be overkill for the mod.
--Snake
  #56 (permalink)
Old 10-19-2009, 08:21 PM
Not really sure of the benefits or possibly damage in high idling a very cold truck from startup. I haven't really used the mod too much except for jump starting someone else's truck or equipment. I have a remote start and just let it run a few minutes before i go out.
