Upfitter switch install. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-15-2014, 05:39 PM Thread Starter
I'm looking to install a set of the factory upfitter switches in my 05 F-350. It has the integrated brake controller, but not the switches. It only has the small opening where the switches should go. SO, Is the wiring harness pre-installed behind the dash for the switches (plug and play) or do I have to get the entire harness as well to do the install?
Thanks in advance!
2005 F-350 Crew SRW FX4.
Mostly stock for now.
New stock turbo 4/14
Sinister Diesel Coolant Bypass Filter.
Coolant cap upgrade.
Zoozad Mod
Blue Spring
6.4 Banjo Bolts
Muffler Delete. Stock Cat
RBV Quarter Horses is offline
post #2 of 5 Old 05-16-2014, 08:37 AM
banshee-rider's Avatar
Quoted: 7 Post(s)
Garage
You need to get the relay harness and switches, then plug and play, its a fairly easy install. took me 45 minutes.
2005 FORD F250 CREWCAB LARIAT
9 INCH LIFT
37x13.50x20 TOYO M/T'S
PMF TRACTION BLOCKS AND BARS
MBRP 4 INCH TURBO BACK
ARP'S,STAND PIPE'S, DUMMY PLUGS ALL THE UPDATES
SCT LIVEWIRE SRLxx
2008 SUPERDUTY TAILLIGHTS
OPT7 LED HEADLIGHTS AND FOG'S, 50 INCH LED BAR
AMP RESEARCH POWER STEP'S
AIR BAG'S TRAIN HORNS AND AIR COMPRESSOR
CUSTOM STEREO
XDP COOLANT FILTER
PSC HYDRAULIC ASSIST STEERING
RCD EGR DELETE
EXCURSION CENTER CONSOLE
2007 REAR VIEW MIRROR AND MIRROR SWITCH UPGRADE
banshee-rider is offline
post #3 of 5 Old 05-16-2014, 08:45 AM
ZMANN's Avatar
Quoted: 1916 Post(s)
agreed get the kit it is plug and play but you need more than the switches like some folks think
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #4 of 5 Old 05-16-2014, 08:47 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Yep, you need the switches AND the relay box.
2005 06 07 Ford Super Duty Factory Upfitter Kit | eBay
05 thru 07 Super Duty F250 F350 F450 F550 Ford in Dash Upfitter Switch Kit | eBay
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 5 Old 05-24-2014, 06:46 PM
I just installed them in my '06 with the small tray and brake controler. I paid $140 from my local dealer for relays and switches. The deal continued to tell me that all trucks were prewired and there was not a relay harness, I supplied the part numbers from forums and schooled them on the switches. The hardest part was removing that little tray.
Gnwdad is offline
