Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
  #11 (permalink)
Old 12-28-2008, 10:24 PM
BlackSmokeStroke BlackSmokeStroke is offline
I am new to this truck and am the second owner, I've got a 99 f350 crew cab and it has a power slider window but behind the rear seat I see the electric arm piece with the wire , I don't think it's hooked up though how do these work usually there a switch or something
  #12 (permalink)
Old 12-29-2008, 05:04 AM
Eric Eric is offline
I HAVE POWAH!!!!!
If it's a factory slider, there should be a rocker switch on the dash. There's 2 wires that come from the motor. I think one is black and the other is gray. Just follow them and see where they go
  #13 (permalink)
Old 12-29-2008, 06:42 AM
Gatorman79 Gatorman79 is offline
Live for Sand Dunes
I have a 05 super cab and did this conversion, the rear window,cable and motor came together. I got this from a late model salvage yard. the conections were already in the truck to plug the motor in and i got a new switch for the dash as the 05 to 07 trucks use the multi function switch for the 4x4,back up sensor and the power sliding switch all in one. I bought the switch from ford and installed it and it works great. If you get the slider used from the salvage yard make sure to get the slider motor mounting bolts and blind nuts from the doner vehicle as they are not there if the truck left the factory without a power slider
  #14 (permalink)
Old 01-04-2009, 09:05 PM
it must be a factory it says powerslider on the exterior of the window on a little sticker, anyway I have no switch on the dash and I have to look into where the wires coming from the motor are going to
  #15 (permalink)
Old 01-04-2009, 10:54 PM
OrangeSS OrangeSS is offline
Send a message via AIM to OrangeSS Send a message via Yahoo to OrangeSS
i have one and hate it....my advice do not waste your time...
my POS takes forever to close and sometimes stops
  #16 (permalink)
Old 04-16-2009, 11:45 PM
so my regulator has a black and a orange wire going into a connector
  #17 (permalink)
Old 04-17-2009, 06:05 AM
SuperdutyKing SuperdutyKing is offline
Location: Savannah, Tenn. (over 100 miles east of Memphis)
I'm kinda the same on that because mine broke and i don't want to give nearly $300 dollars for a new regulator. So i put solid back glass in mine and love it. No more screwing with trying to keep it closed.
Also if anyone is interested in a factory power silding glass, i have my old one. Needs a new regulator, but will come with the gasket, a layer of 5% tint already on it, and the motor. Anyone interested just let me know.
  #18 (permalink)
Old 04-17-2009, 06:36 AM
wriott wriott is online now
BUILT & BROKE BY ME
im interested, how much shipped to 48429
  #19 (permalink)
Old 04-17-2009, 10:33 AM
actually the wires coming off the regulator are red and a yellow I need to know what to do with the wires they have a gray connector piece attached that should plug in somewhere else
  #20 (permalink)
Old 04-17-2009, 12:54 PM
I'll have to check on shipping, but how does $200 sound for glass, not including shipping yet?
