2003 crew cab carpet - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-28-2014, 04:44 AM Thread Starter
I have a truck that i am rebuilding, long story short i needs a new carpet, the cab is from a manual shift, and i have an automatic trans setup. my question is can i order a carpet for a crew cab automatic and it will fit the manual ok other then the hole for the shifter in the floor? I have a block off plate for the floor so no issue there just want to know if the floor pan is molded different for the manual vs the auto or do they just cut the hole for the shifter?
Thanks!
JonnyArch is offline
post #2 of 3 Old 05-08-2014, 09:01 AM
Lubbockguy1979's Avatar
Quoted: 8 Post(s)
Send a message via Yahoo to Lubbockguy1979
I believe the transmission tunnel is different for the manual. Might talk to the people making the carpet and see if that is precut in the new carpet and if not if they could just not cut it out
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
post #3 of 3 Old 05-08-2014, 09:31 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Manual hump is a bit bigger but you could fit an automatic carpet just fine. i had a 98 dodge manual that i put an automatic carpet in and there was a slight difference but not enough that it didnt fit all the other holes. If your interested i have a carpet for sale grey crew cab automatic check my link in my sig
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
