Originally Posted by lancinfish
I want to remove the center seat and ad armrests to my bukets. Is this possible?
What do I need to do this other than the armrest? Is there a bracket that must be installed inside the seat?
I dont like the Center Seat and want a regular center console. If you all can help me figure this out, I will be getting rid of my center seat. I searched and did not find anything. Has anyone done this before?
Pat Bustle
ok well found a guy local that was selling the center fold down seat/Arm rest with storage in the back you know the center of 40/20/40 as I assumed before, the arm rest's had to come off, to do this I pulled the fabric back from around the pivot side of arm rest's, then the foam, and there is a torx head screw in there remove it arm rest pop right off, how ever to answer the original queston there is a bracket in the captains chair i DONT BELIEVE THERE IS IN THE NON CAPTAINS CHAIRS, and the studs the arm rest pivot off of these they did not appear to be removable in any way with out cuttin the fabric back or removing the entire seat back cover I did not want to do this so I covered my seats up to protect them and used a cut off tool and cut them off, and plenty of clearance and the center seat blocks the brackets from sight up or down. with the center console because I had the factory floor console, I did not have the rear studs for the center seat installed, I had to pop some threaded certs into the floor and put my own studs in to anchor the rear of the center jump seat but beside's that the fronts bolted in with the exsisting captains and it looks factory just like 40/20/40. hope this helps.
