2008 column shifter - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-07-2014, 08:54 AM Thread Starter
jake_duet's Avatar
2008 column shifter
Has anyone ever installed a 2008 column shifter into a 03-07 powerstroke? I can get my hands on a parts truck and was wondering.. I also love the look and love how much shorter they are.
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #2 of 4 Old 04-08-2014, 05:08 PM
6.0f250firstcar's Avatar
I'd take it out of the parts truck and then take the steering column off your truck and see how the 6.0 shift lever is attached and if you can simply unbolt or unscrew it and put the other one on. It might require the newer steering column because idk if the shorter one will hit on the 6.0 steering column.
Only way to find out is to try
Ryan
6.0f250firstcar is offline
post #3 of 4 Old 08-08-2014, 04:09 PM
superBADduty's Avatar
Quoted: 18 Post(s)
Garage
Did you get any where with this?
2007 F250 KR CCSB 4x4 ARP's, PMM's EGR delete, PMM's coolant filter, SCT Sf3, GearHead's SRL & SRLXX, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel 2, No Limit Fab. CAI., 2008 rear differential cover.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
2008 F250 KR CCSB 4x4 quad buckets minimax "SOLD"
superBADduty is offline
post #4 of 4 Old 08-13-2014, 11:28 AM
Fox Hunt's Avatar
Quoted: 30 Post(s)
Interested as well
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
Tags
2008 shifter , gear selector , shifter , steering column
