Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 11-26-2008, 10:49 AM
FastFocus FastFocus is offline
Send a message via AIM to FastFocus
Pillar Gauge Pod question
ok, i need an EGT gauge installed, and possibly a boost gauge. Was thinking of putting it on the pillar, but i dont want to lose the handle. Do you know if a 1 or maybe even a two pillar pod will fit under the handle? how do they typically fit and look?
Old 11-26-2008, 10:52 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
no it will not... only a single will fit under their.... im assuming since your not also getting a trans temp you have a 6speed?
you could always do an overhead pod that mounts next to your rear view mirror...
Old 11-26-2008, 10:56 AM
the overhead pod sounds like it would be a cool idea. and no its a Torqueshift,,, thought the factory trans temp would be ok because i'm not on it a lot.
Old 11-26-2008, 11:00 AM
the factory trans temp gauges is useless.. its just a dummy light... you need an aftermarket trans temp gauge....... if you wait until friday to buy we will be running our black friday sale.... youll get free shipping and the free colored match paint... either way here is a link on the kit: Auto Meter Gauge Kits
here is what the overhead pod looks like:
POWERED SPARKLESS POWERED SPARKLESS is offline
CAN'T YOU SEE I'M BUSY
The stock trans temp is more like an on/off switch. Stick with Raul he'll take care of you.
Old 11-26-2008, 11:12 AM
hmmm, ok. Well, how off is the stock boost gauge too then. was gonna work with only the EGT really. but guess i'll just go ahead and get all 3.
will probably stay with the 3 pillar pod then. dont need the handle THAT bad.
Old 11-26-2008, 11:17 AM
the stock one is accurate until you add a boost fooler and then its not accurate anymore..... my suggestion is to just get all 3...
Old 11-26-2008, 11:27 AM
iLoveSoccrMoms15 iLoveSoccrMoms15 is offline
I'll 3rd the option of getting a tranny temp gauge. I don't currently have one, but I just had warranty done to my tranny because it overheated and destroyed my torque converter and tranny pump. My stock tranny temp gauge didn't even move from it's position of "normal".
I'll be ordering one soon so I can avoid losing my truck for a week and a half.
Not meaning to hijack, but Raul, what would the price be for a tranny temp gauge made by ISSPro? Black face and housing with standard lighting (no special green or blue color). Thanks in advance...
Sergio
