help : driver side seat will not go backwards - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-23-2014, 10:45 AM Thread Starter
need some help , driver side seat will not adjust backwards it will go up down forward but the direction i need it to wont budge . no sounds what so ever like it even trying to . i think the switch is bad but does anyone have a wire diagram so i can test and see if its getting any power to the motor? what color wire and tracer if it has one is the backwards wire? thanks
04 f250 xlt the seat has the two up and down buttons and the square that slides up and down and front to back in the center .
mx730md is offline
post #2 of 2 Old 04-19-2014, 06:36 AM
"DILLIGAF"'s Avatar
Quoted: 11 Post(s)
Garage
Replace the switch, I had the same issue, new switch all is good again!
Early 04 F250 4x4 CCSB
SCT Livewire tunes from MPT
Studded, head gaskets, EGR, EGC Delete, Blue spring, Sinister Coolant filter, 4" exhaust, Magnaflow muffler
"DILLIGAF" is offline
