Dome/Cargo lights question - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-22-2014, 03:30 PM Thread Starter
trophy_23's Avatar
I asked in the main section with no luck so figured I'd try here....
My Dome & Cargo lights will not come on when keyless entry is used, however all of my running lights are illuminated. The Dome & cargo do work correctly if door is opened, or if the dome light switch on dash is manually 'rolled up until it clicks' and turned on.
When I lock the truck with the key fob, the dome light will stay on for about 30 seconds, then turn off. Is this a programing option that can be changed so the interior comes on when the keyless remote unlocks the truck?
As a secondary question, are all 3 of the bulbs in my ex cab dome light 578 festoon or are the 2 map lights 194? I would like to change them to LED and I couldn't find it in the manual, only info I can find here on the site are crew cab's with a different setup. I want to tie in for puddle lights.
Thanks in advance
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
