Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 11-17-2008, 06:56 PM
tech10002 tech10002 is offline
Removing armrest mount without cutting
Has anyone ever managed to remove the armrest mount from the seat without having the cut off the shaft? I have a center seat coming I got through a barter deal to replace my console, but I need to get the arm rests out of the way. I'd rather not cut anything if I can avoid it in case I ever want to put the console back. The only person I've ever seen do this cut the shafts off that the arm rests bolt to.
Old 11-18-2008, 05:10 PM
Aronda1125 Aronda1125 is online now
Send a message via Skype™ to Aronda1125
The cover comes off the cushion and there's a large torx head bolt that you can just unscrew. I took mine off to put in an '08 console.
Old 11-18-2008, 07:23 PM
Does it leave anything protruding out? I just picked up the right bit, so I haven't had a chance to take it apart yet.
Old 11-20-2008, 01:25 PM
No, nothing is left protruding out. The only problem is the there's gonna be a hole in each seat where they mounted.
Old 11-20-2008, 07:35 PM
Cool, thanks. That will save me tons of time since I don't need to take apart the seat.
I might make something to cover the hole. I was thinking of using 2 pieces of thin sheet metal or plastic cut in a 1.5" circle and then crimping a snap on each piece and covering the outside piece with vinyl or leather.
Old 12-05-2008, 12:27 PM
joeficsit joeficsit is offline
pics of the uninstall of the armrest would be great, oh, and a finished shot of the interior. thanks.
Old 12-08-2008, 09:39 PM
chicago6.0er chicago6.0er is offline
How did this work out for you? I got my jump seat off ebay about a month or so ago and just getting around to installing because my 4th child was born. I removed the armrest but there still is a pin sticking out that supports the armrest. Looks to be part of a bracket that also stick out of the side of the seat. From what others are saying they has to remove the seat cover and cushion and cut the bracket off the frame. I hate to do this because one day I would like to take the jump seat out and go back to the console.
