Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 11-06-2008, 06:20 AM
regor regor is offline
HVAC IN NC
shift knob?
Do the shift knobs on our trucks just twist off? If they do mine is super tight, and does anybody know what size the threads are?
Old 11-06-2008, 06:34 AM
Goose Goose is offline
Sponsored By MOM
Send a message via AIM to Goose Send a message via Yahoo to Goose
it is splined and very hard to get off if u get it off i will buy it off of u
Old 11-06-2008, 07:16 AM
HVAC IN NC
Is there a bolt under the shift pattern insignia or is it just glued down on the splines? If so i guess you could heat it and it might loosen it up.
Old 11-06-2008, 08:02 PM
HVAC IN NC
Any body else know anything about them? Or have tryed to get them off to put on a custom knob?
Old 11-06-2008, 09:37 PM
03f250stroke 03f250stroke is offline
like said above they are splined. you can twist very bit side to side and keep pulling up. it will go. i had a manual f150 with the same knob on there. its a little tricky but it will finally just slide up
Old 11-06-2008, 09:43 PM
2005F250 2005F250 is offline
You can get your girlfriends hair dryer and try to heat up the glue on the splines to get the knob off. I think its glued on.
Old 11-06-2008, 09:48 PM
TxPSD9673 TxPSD9673 is offline
lol i have the opposite problem, my shifter knob will come off in your hand if your shifting aggresively so i think my glue is gone lol
Old 11-06-2008, 10:04 PM
ford_trck ford_trck is offline
I blame the dog
Send a message via AIM to ford_trck
It is splined on. If you use a wrench or crescent wrnech the size of the shaft and a hammer you can get them off. Generally in 3 smacks or less
Old 11-06-2008, 10:19 PM
HVAC IN NC
Thanks for the answers guys, i want to change the knob, I guess i would have to have threads cut on to it to put a aftermarket knob on there i will have to do some searches now to see if any of them are splined like ours. Thanks again
