Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 10-22-2008, 07:02 PM
barney01 barney01 is offline
Can you disconnect the chime?
I was wondering if anybody knew how to disconnect the chime on an '07 f250? Crawled up under the dash and removed the fusebox and still could not find it. Any and all help is greatly appreciated.
Old 10-22-2008, 07:14 PM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
what would be the point of this??? do you just sit there with your keys in the ignition with the doors hanging open??
Old 10-22-2008, 07:19 PM
nic0084 nic0084 is offline
Its annoying when you listen to music with your door open. And just annoying period.
Mine was a little black box that I yanked out from its connecter just above the go pedal, not sure that yours is the same though, being that Im a 97 and you are an 07.
Old 10-22-2008, 07:21 PM
Lonno Lonno is offline
Search the forums, theres been a couple of threads about this. Good luck.
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
the reason youcant find the chime is because its buil into the internals of that fuse box you pulled loose , can not bypass it
Old 10-22-2008, 07:22 PM
choctaw choctaw is offline
I'm #1 in the #2 Business
I do this sometimes, especially if I'm watching my guy's working or writing an invoice.
Old 10-22-2008, 07:23 PM
gygers gygers is offline
Land Yatch Driver
Ya I have an 02 and can't find the door dinger either. I hate that annoying p.o.s.
I disconnected mine. I pulled the ignition out and took the little connector out and put tape on it, works fine.
I'll look for the thread.
Old 10-22-2008, 07:32 PM
TxPSD9673 TxPSD9673 is offline
OR look in the back of the owners manual and it TELLS you how to disable any of the chimes ANY trust me did it for my dads 06' its a whole bunch of stuff you do in sequence anyways just look in the book.
Old 10-22-2008, 07:37 PM
Land Yatch Driver
I did that with my auto door locks, I'll look to see if I can do the door dinger.
