Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
  #11 (permalink)
Old 10-22-2008, 07:40 PM
TxPSD9673 TxPSD9673 is offline
you can thats the main one my dad HATED soooo much especially at the deer lease and also the seat belt dinger cus who uses seatbelts cruising 5mph on a ranch???? it got reeeeaaaaal annoying
  #12 (permalink)
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
Originally Posted by choctaw View Post
I disconnected mine. I pulled the ignition out and took the little connector out and put tape on it, works fine.
I'll look for the thread.
you can get rid of the key chime that way , yep sure can , i was thinkin he wanted to cut all the buzzers off ,belt and all
  #13 (permalink)
Old 10-22-2008, 07:52 PM
Dusty's Diesel Dusty's Diesel is offline
I have done several of them this way. Here is a thread listen to radio w/ doors open?
  #14 (permalink)
Old 10-22-2008, 08:00 PM
barney01 barney01 is offline
On the occasion that I take to cleaning the interior, it is awful hard for a fat man to do it with the doors closed and it gets awful hot in Texas with the windows up and the doors closed. I just thought that someone may have found the hiding place for the little bugger by now.
  #15 (permalink)
Old 10-23-2008, 10:37 AM
WEWILLE WEWILLE is offline
ready for spring
You can turn it off with fords ids too.
  #16 (permalink)
Old 10-26-2008, 06:58 AM
raveer2000 raveer2000 is offline
Resident Tire Smoker
Try this.
https://www.motorcraftservice.com/pu...9/S6OD1012.PDF
  #17 (permalink)
Old 12-14-2008, 01:25 AM
14mins 14mins is offline
On a 2005 f250 diesel you remove the 3 phillips headed bolts that are under the sterring wheel, plus the cover under it. ( pull straight out and let it drop down to free the bottom. Look for a black wire with a pink line running thru it. I just cut mine. End of annoying chime. Some guys do a better job and take the wire off where it joins the key tumbler. My after market stereo make it 10 times louder for some reason. Takes 3 minutes to do this and well worth it.
  #18 (permalink)
Old 12-14-2008, 05:30 AM
nsrchofpwr nsrchofpwr is offline
lifetime member
subscribed
  #19 (permalink)
Old 12-15-2008, 07:40 PM
jcproulx3 jcproulx3 is offline
the chime is on the back of the instrument panel. i took mine out and cut the little sucker off the board works great just a pain to tear the whole instrument cluster out to get to it
  #20 (permalink)
Old 02-11-2009, 05:22 AM
bigjack67 bigjack67 is offline
Can anyone tell me how to disable the auto locks and the dinger? I just bought an 06 and it didnt come with a manual. thanks
