door ajar light - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-05-2014, 03:32 PM Thread Starter
door ajar light
Hey I have a 03 6.0 and all the sudden the door ajar light won't go off. Anyone eles have this problem?
bigjstang is offline
post #2 of 4 Old 02-15-2014, 01:31 PM
My 03 was doing the same thing, searched the forum and found the fix. Spray some wd40 into the latches on your doors. It's caused by dirty contacts.
Did this on mine and they've been fine since.
rieggs is offline
post #3 of 4 Old 03-10-2014, 09:21 AM
Stiles's Avatar
As weird as this will sound WD-40. Not PB Blaster or any other good spray lube or penetrating oil. It seems good old WD-40 dose the trick.
Shannon
05 F-250 CC, LB, Lariat, FX4 138K
2.5" leveling kit, No EGR, Studs, Bullet Proof up grades
Airaid intake, aFe 4" Turbo back with muffler
SCT Livewire TS with EGT, Sinister Coolant Filter
8 New Ford OE Injectors, Blue spring,
Vented & Cross Drilled Rotors
2way Alarm With Remote Start,
Live Tuned by Jody of DP Tuner
Mishimoto Radiator...
Late 99 F-350 Dually 2wd EX-Cab Flat bed 130K
Stiles is offline
post #4 of 4 Old 03-10-2014, 06:36 PM
downfour's Avatar
Same issue. Wd did the trick for me as well!!
Sent from AutoGuide.com App
03 f-350 4x4 lariat dually 6.0
studded and deleted
6 inch miters- for sale or trade for 5 inch single
ccv mod 05-07 grill
pillar gauges
more to come
downfour is offline
