Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 10-06-2008, 06:34 AM
Blitanicle99 Blitanicle99 is offline
Gauge location with custom tweeters in the a piller?
I am getting a set of tweeters put in my A pillars, some nice Memphis components.
I want to keep my handle to get in my truck ( I have no step bar) and still want to get some gauges..
Where else could I mount the gauges on my 03 CC?
Old 10-06-2008, 06:51 AM
szyd szyd is offline
PM Raul at Stealth performance. He has a few diferent pods under dash,above rearview mirror, and ther are ones that look factory where the factory guages go. He can pm you pictures.
Old 10-07-2008, 05:16 AM
SPL2K SPL2K is offline
You should have plenty of room to put the tweeters and a couple of gauges in the A pillar. The tweeters need to be down low on the pillar closer to the dash.
Depending on how tall you are and how elevated your seat is (if its power seat) the tweeter should be at or just below shoulder level.
Old 10-10-2008, 10:17 AM
Granny Granny is offline
The Corner Mod
Send a message via Yahoo to Granny
I have the over head pod for my gauges( pyro, tranny, and boost). I like mine there. It helps keep the sleeper look to my truck and they are easily seen, because you use your rearview mirrow anyway, so you can just glance at your mirrors. Here is a pic of my overhead gauges. ]
Old 12-09-2008, 04:21 PM
pitamarillo84 pitamarillo84 is offline
heres what i did for the tweeter install it keeps it off the a pillar and is aim correctly plus i think it looks cleaner that way instead of the pillar
Old 12-09-2008, 05:25 PM
alabamafrog alabamafrog is offline
Powerstroke Techie
I like my over the mirror mount, easy to read, doesn't block view, blocks morning or evening sun. The mount was $50.
Old 12-11-2008, 11:00 AM
FionaThe02PSD FionaThe02PSD is offline
I have the over the rearview mirror setup as well. Mine required some modification to get the mirror up enough to see out the back window. Make sure you find a good ground, it is critical.
