Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 09-30-2008, 08:59 AM
detroitdiesel64 detroitdiesel64 is offline
vent air flow problems
I have a problem with the air not flowing through my vents. when i hit hands/feet, feet, or hands the air goes straight to the dash. i think the directional flap might be broke but im not sure? if that is the problem is it easily assessable or does the whole dash have to come off? any and all comments appreciated. thanks
Old 09-30-2008, 09:21 AM
Lonno Lonno is offline
I have the same problem. Thing is totally retarded.
Old 09-30-2008, 09:25 AM
yeah it sucks. what r u gona do about?
Old 10-11-2008, 10:19 PM
03f250stroke 03f250stroke is offline
my truck does this..when i use the a/c...its a vacuum leak, something with the 4x4 i believe
Old 10-12-2008, 06:40 AM
FloridaStroker FloridaStroker is offline
Yes, the system has a vacuum leak somewhere. It's easy to track on this trucks as the vucuum system only controls the front hubs and the vent system for the HVAC system. Check all the lines starting with the pump on the passenger side under the hood and just follow all the lines to make sure non have come undone or been damaged.
Old 10-17-2008, 07:29 PM
kinghawg98 kinghawg98 is offline
and the heater valve..top of engine on one of the coolant hoses. I found mine had slipped off, never noticed it, but it solved all my woes.
Old 10-19-2008, 07:09 PM
deviusdragger deviusdragger is offline
what if I have warn hub locks? My vents aren't working either. Could it be something with a fuse?
Old 10-21-2008, 11:11 AM
ketron10a ketron10a is offline
off topic.....love the sig devious....and yes...thats a hell of a lot of hella lights LOL
Old 10-21-2008, 12:15 PM
hahaha thank you bro. :-)
Old 10-25-2008, 09:09 PM
pipelinetrash918 pipelinetrash918 is offline
I recently got an 03 F350 6.0 with 30K mi. After a week or so it started doing this when I would start it up, however after a few minutes and some weired noises it would start to blow through the vents. So I looked around under the hood and noticed a vaccume line near the A/T dipstick was disconnected. I reconnceted the line and it started working normal. Maybe this is your problem
