08 6-disc radio install? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-02-2014, 10:42 AM Thread Starter
6.0Stroker's Avatar
Quoted: 957 Post(s)
Does anyone know if a 2008 6-disc cd player will fit in my 03 that has a single disc? I know ford was good about making part swaps easy and many vehicle from many years will interchange, but has anyone done it?
I can get it for like $30 so I may just get it and see what happens.. but thought some insight would be helpful.
Thanks
MIKE "HOSS" THOMAS
'03 F350 6.0 6-speed
~EGR Delete~Ported Intake Manifold~4in Diamond Eye Dual Exhuast~Blue Spring~50MM Turbosmart BOV~PMM Coolant Filter~
~155/stock Warren Injectors~Terminator Engineering T500 HPOP~SouthBend Dual Disc Clutch~RCD Stg 2 Camshaft~
~'03 Nighthawk turbo w/Wicked Wheel2
~Rebuilt and Studded by Toren~
6.0Stroker is offline
post #2 of 5 Old 01-02-2014, 03:06 PM
william_ace's Avatar
Quoted: 2 Post(s)
No sir. It won't fit without some major modifications.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
The Following User Says Thank You to william_ace For This Useful Post:
6.0Stroker (01-02-2014)
post #3 of 5 Old 01-03-2014, 09:31 PM
Quoted: 8 Post(s)
I installed a 6 disc MP3 from a Focus into my '05:
Still have the stock 6 disc (not MP3) from my 2005 available if you're interested.
Doward is offline
post #4 of 5 Old 01-04-2014, 08:39 PM
05-07 has a larger dash area for the newer radios, that is why your focus radio fit with no problem.
04 and below has a smaller opening, and still require the old U-shaped tool to remove the radio.
and if i'm not mistaken they also changed connectors too one of those years.
fordtrucknut is offline
post #5 of 5 Old 01-04-2014, 09:15 PM
ZMANN's Avatar
Quoted: 1905 Post(s)
agreed .......................
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
