4 pod guage and edge dash pod ? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 12-29-2013, 08:55 AM Thread Starter
HP MACHINE's Avatar
Quoted: 104 Post(s)
Question 4 pod guage and edge dash pod ?
Has anybody got a picture of a pillar pod with 2 , 3 , or 4 guages and a
edge CS/CTS dash pod ? Can you see the bottom guage ok , and can it even
be done ( as in interference between the 2 ) ?
Thanks
HP MACHINE is offline
post #2 of 14 Old 12-29-2013, 09:14 AM
Koda22's Avatar
Quoted: 5 Post(s)
Don't think it would fit, atleast not with 4 gauges....but I think you could do a quad pod, then only use 3 gauges, and an adapter to use the 4 hole for the cs/cts
Koda22 is offline
post #3 of 14 Old 12-29-2013, 02:15 PM
william_ace's Avatar
Quoted: 2 Post(s)
I just took my dash pod out because it wouldn't fit with the 3 gauge pillar.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #4 of 14 Old 12-29-2013, 02:25 PM
Raul@Stealth Automotive's Avatar
you can always mount the CS or CTS on the last gauge whole with their gauge pod mount adapter...
william_ace likes this.
Raul@Stealth Automotive is offline
post #5 of 14 Old 12-29-2013, 02:27 PM
Koda22's Avatar
Quoted: 5 Post(s)
That's wat I was trying to say....lol
Koda22 is offline
post #6 of 14 Old 12-30-2013, 05:27 AM Thread Starter
HP MACHINE's Avatar
Quoted: 104 Post(s)
Thanks guys , hate to buy everything and find out the hard way . I wish you could
get a pod/mount to install the CTS in line with the steering column either on top of
the dash or like the 2 guage one that mounts on top of the column .
Dam , something else to invent LOL .
post #7 of 14 Old 12-30-2013, 06:36 AM
Koda22's Avatar
Quoted: 5 Post(s)
You could always mount it above the rear view mirror....that's where I've got my insight...and have the quad pod on the pillar
Koda22 is offline
post #8 of 14 Old 12-30-2013, 10:43 AM Thread Starter
HP MACHINE's Avatar
Quoted: 104 Post(s)
Interesting , do you have a pic ? And was it a chore to get the cables run / hidden ?
post #9 of 14 Old 01-01-2014, 11:30 AM
snafu!'s Avatar
You have to mount the pod adapter upside down so it's facing the window, not like the second pic.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #10 of 14 Old 01-01-2014, 11:45 AM
03Cody's Avatar
What I'm going to try and do is use the edge pillar mount that I have now and a triple gauge pillar pod. I'm going to run the cs wires through the lowest gauge pod and cover it with the edge pillar pod. Then just use the top two for two gauges. I think someone on here has done it before. I think it looks really clean.
-Cody-
03Cody is offline
