Interior Noise - Ford Powerstroke Diesel Forum
post #1 of 20 Old 12-04-2013, 03:36 PM Thread Starter
Interior Noise
So I just got through driving my first long road trip and I noticed a huge difference in interior noise in my 05 compared to my 08 with a lift and mt. What is the difference as far as padding and seals and everything? Is there anything I can do to quiet down my interior noise? I'm not concerned with the exhaust note, just all the road noise! Thanks for any insight.
David
2005 6.0L F250
EGR Deleted
merkfalc is offline
post #2 of 20 Old 12-04-2013, 03:43 PM
66Bronco's Avatar
Take out the interior and dynamat everything.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #3 of 20 Old 12-05-2013, 03:23 PM Thread Starter
But why the difference between the 05-07 and 08 and above? Is the carpet thicker or additional padding on?
2005 6.0L F250
EGR Deleted
merkfalc is offline
post #4 of 20 Old 12-18-2013, 10:07 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
That's exactly what I did and then some. I also put 1" self adhesive foam rubber inside the doors as well as under the cab.
As far as the 08 the 6.4 is much quieter then the 6.0. Not sure if they did something different for sound but you are right these trucks are noisy.
My truck now is silent especially when up to speed you can't hear any road or engine noise. It's a lot of work but well worth the effort.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #5 of 20 Old 12-19-2013, 04:38 AM Thread Starter
Thanks for the reply. Ever heard of anyone using lizard skin?
2005 6.0L F250
EGR Deleted
merkfalc is offline
post #6 of 20 Old 05-30-2014, 04:59 PM
rebelranger's Avatar
Bringing up an old thread but I'm about to start trying to quiet my truck down. I ordered 36sqft of lizard skin Damplifier Pro for the doors and tranny tunnel. Only need 25% coverage. Also ordered the Excursion driver side hush panel from Ford which I got lucky and was able to get one from Ford. I'm also ordering some MLV (dB-3 4 ft. x 8 ft. Acoustical Barrier). then going to do the door seals with latex tubing.
Currently at 70mph, 1950rpm, no radio my truck is 80db. Hopefully I can get it under 70db. It's going to be a week before I get to this project, due to military field exercises.
rebelranger is offline
post #7 of 20 Old 05-30-2014, 06:20 PM
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
I have heard good things about the spray on lizard skin, I have no experience myself but well versed on dynamat along with foam rubber sound matting. There is a fair amount of noise coming through the driver side firewall. Make sure to deal with that area.
I myself put the 1" self adhesive foam rubber against entire firewall as well as inside all of the doors (complete coverage).
I also installed a aftermarket carpet kit that had 1/4 rubber backing on it for sound control.
As far as the biggest problem areas go the doors and firewall is where the largest amount of noise comes through at. But if you really want a silent interior you have to do it all.
I can honestly say that my trucks interior is silent going down the road. It's like a Cadillac inside since doing all the DynaMat and all. The difference is stunning, I will take truck out and see what the db level is. I will report that back this evening if I can. I am curious what the # is myself.
Post up your results by all means with the Lizard Skin
Atlas40
BPD Waterpump
Fabtech Radius Arms
post #8 of 20 Old 05-30-2014, 08:01 PM
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Ok I took out my truck and used my dB meter.
Taken with a: "dBchecker DB01" Sound Level Meter
@ idle 51dB
@ 40mph 63dB
@ 60mph 66dB
@ 70 mph 67dB
Engine speed at 70 mph is at 1750 + or-
Truck has a 4" exhaust with a Donaldson straight type muffler
Toyo 38/15.50/18 M/T tires
Taken without the a/c fan going and no radio.
Yea it's quiet I should have took a 80mph reading but I doubt it is any louder then 70mph.
Wish I had data before installing sound proofing but I can say it was loud inside truck. It reminded me of the rides to school in the big school buses. Way too much engine noise regardless whether you like the sound of Diesel engines or not.
Yes it's worth every minute of the effort to install soundproofing.....................
Atlas40
BPD Waterpump
Fabtech Radius Arms
post #9 of 20 Old 06-08-2014, 09:54 AM
Well I got the excursion hush panels today from a pick n pull yard for $25 and on the ride home it dropped the 70mph db by 1 on my phone sound meter. However at idle it is the most noticeable to the ear. All my sound measurements are for 60-70mph because honestly under that my truck is pretty quiet, in the 65db range. This week I'll be piece mealing the CLD, CCF, and MLV installs.
post #10 of 20 Old 06-08-2014, 10:37 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1665 Post(s)
Feedback Score: 4 reviews
Where do you get your 1" self adhesive foam rubber stuff?
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is online now
