water in cab - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-13-2013, 01:04 PM Thread Starter
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 55 Post(s)
Feedback Score: 7 reviews
water in cab
every now and again ill find water on the pass. floor board and trace it up to the firewall right under the dash. it is only water, no coolant.
there was a pretty good amount today, it has also rained for a week straight. its all over the silver cylinder thing on the firewall... any ideas what this is?
my truck is a xl so its not ruining carpet or anything, just annoying.
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #2 of 7 Old 10-14-2013, 06:44 AM
Huntersk2k5's Avatar
When this happened in my truck I discovered the seal on the air intake for the heater fan under the cowl was leaking. It would fill up the housing and leak through the vent on the passenger side under the glove box. I just pulled the inner fender back and drilled a small hole in the bottom to allow the water to drain. This is a pretty common problem apparently as I've done the same thing on my dads and uncles super duties.
2005 F250 Super Cab
AFE Stage 2 CAI
4" Turbo Back Exhaust
EGR Delete
ARP Studs
Sinister Coolant Filter
ELC Coolant
Edge Insight CTS
Atlas 40
Custom Tunes
2.5" Ready Lift Leveling Kit
35" Toyo Mts
Huntersk2k5 is offline
post #3 of 7 Old 10-24-2013, 05:36 PM
Mine tends to do this on the driver side any ideas?
05 kingranch4x4 is offline
post #4 of 7 Old 10-31-2013, 01:53 PM Thread Starter
Quoted: 55 Post(s)
there is a opening to the upper left of the steering shaft, mine has a taped cover thing on it. yours might be leaking.
post #5 of 7 Old 10-31-2013, 02:00 PM
Texas Proud
charlie.thomas's Avatar
If you have a sunroof they have a tendency to leak, mine is and it's leaking in running down the driver pillar to the floor board
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #6 of 7 Old 12-18-2013, 01:54 PM
Quoted: 3 Post(s)
I'll second this.
My air intake was leaking and filling up the fan housing as well.
Pull out the fan (three bolts), and I bet you will find the bottom of the housing full of water. It can only get so full before it starts to leak out the blend door... on to the passenger side floor.
Ford in their infinite wisdom neglected to bother to put a drain hole in the bottom of the fan housing to overcome this issue. Once water gets in there by any means, it has no way out.
If you pull the fan out, you can get in there with a drill and poke a hole in the bottom of the housing. It is on the "intake" side of the fan, so it doesn't really matter how big you want to make it (make it big enough it won't plug itself back up with slime/goo/mud/dust).
My floor's been dry ever since.
If it is your sunroof leaking, you'd probably find water in your glove compartment too (had that problem at the same time as well).
Lee
ve7fet is offline
post #7 of 7 Old 11-09-2015, 06:12 AM
water leak in cab
I was chasing the same issue and it ended up being the third cab light up on the back of the cab. Pulled it off and found the gasket to be missing a section and it was still wet in there. I also could see where the water was traveling. I installed a new one last night, hoping this fixes it. I also pulled the cowl off under the windshield and there was a bunch of junk in there as well that i cleaned. Hope this helps anyone facing this problem. See attached photos.
ID:	478681   Click image for larger version
2006 Ford F250 CC 4x4 6.0
161k miles, turbo back exhaust, intake
Jasher20 is offline
