Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 07-10-2008, 06:01 AM
kkonen kkonen is offline
Autometer Gauges and Installation
I am considering a set of gauges (EGT, trans, boost). I am trying to decide which ones I want. I have decided to go autometer, but unsure of the line. I am thinking C2s. I want them to blend in to the look of the interior as much as possible.
As far as installation goes, how do you get the wires from the engine compartment into the cab? Do you drill a new hole and grommit? If so, what do you use to seal the hole?
Thanks.
Old 07-10-2008, 06:12 AM
choctaw choctaw is offline
I'm #1 in the #2 Business
I'm going with the GS, they are black/white numbers during the day and glow green at night with a red pointer. These seem to be the closest I have found in Autometer. I think there is already a grommit in the firewall.
Old 07-10-2008, 06:16 AM
ricksstang ricksstang is offline
Gauges
On my 95 psd I went thru the plate bolted in place of where the clutch master would be mounted. Took the plate off drilled a hole in it remounted it with a grommet in the hole ran the wires then sealed the hole with a little RTV.
I used Autometer Sport Comp gauges because they looked good with my interor, and because of the price. Good luck
Rick
Old 07-10-2008, 06:26 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
their is already a grommet in the firewall.... just fish the wires through their.. the C2's look great... they wont match your interior bud they look good at night
Old 07-23-2008, 08:47 PM
blizzardwarrior7 blizzardwarrior7 is offline
Send a message via AIM to blizzardwarrior7
Yea there are several holes with grommets already there. I however decided to go through the trouble of drilling a new one, cause I needed to fit a hella lot of wires through it....trust me, its not easy to do.
Old 07-23-2008, 08:48 PM
Did you decide on gauges?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
