A/c and heat problems - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-11-2013, 10:38 AM Thread Starter
Silverbullet 6.0's Avatar
I only have defrost when I turn heat on no matter if it's set on floor it comes out only defrost and a/c don't work at all, what should I do to at least fix the heat for the winter?
Silverbullet 6.0 is offline
post #2 of 5 Old 11-16-2013, 06:23 AM
allergic to hot weather
95and05's Avatar
Send a message via AIM to 95and05 Send a message via MSN to 95and05
Just saw this... fixed yet?
Is the vacuum pump on the passenger side fender working?
Keith in Alaska (lovin it)
94 IDI
95 7.3 ex cab L/B 4X4 (D66 stage 1s 4" Turbo back 6637 air filter and bully dog chip)
05 6.0 Excursion 4X4 (stock)
10 6.4 F350SRW CCLB manual trans (stock)
95and05 is offline
post #3 of 5 Old 11-16-2013, 09:23 AM
mattdoxa's Avatar
Could be as simple as a cracked vaccume line. Or just dissconnected, my truck was doing the same thing. Apparently it sets it self to defrost as a default setting
06 king ranch dually. 4" silverline duals, sct x3 tuned by tony wildman.
arp studs rcd egr delete updated fpr 6.4 banjos warren 175/stock. stage 1 from mtw,
mattdoxa is offline
post #4 of 5 Old 11-19-2013, 03:10 AM
happyhrs's Avatar
Question Same issue
Hey guys having the same issue. Seems to just have happened ths morning. where is that vacuum pump? Anyone have a picture of it?
2005 F350 PS
4" Banks exhaust
Airraid intake
Edge cs
Juice w attitude
Bilstein Shocks & Stabilizers
Firestone rear airbags
onboard air compressor
Texas train horns
Blue Spring Update
happyhrs is offline
post #5 of 5 Old 11-26-2013, 02:52 AM
SpeedyDBall's Avatar
I have a similar problem. all my controls work except for the floor. When I put it on the floor it only blows out at the defroster. I guess Ill check some vacuum lines.
'05 6.0 FX4 Lariat DRW:ARP, OEM HG's, Fully Updated, 03 turbo, Warren 155/stock, Pillar Guages(Boost, TFT, EGT, Oil Pressure), Fuel Pressure, Scan Guage 2, 6.4 banjos, Blue spring, MBRP straight pipe, SCT with Nate's tunes, Zoodad, DIY CCV Mod, coolant filter, T6, Final Charge ELC, Strategy VXCF4, Eco tuned FICM
Ficm Repair.com is the $%^&!!!!!!! Great service, and Ed is great to work with. Highly recommended!!!!!!
SpeedyDBall is offline
