info on guages - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-04-2013, 04:31 PM Thread Starter
info on guages
need some info,Just had 05 6.0L rebuilt bulletproofed, and i am not sure if i should put indivisual guages or all in one unit ( guages and programmer) does would like some feedback on this i just want to do it right and not have to replace it in 6 months.
rolin17 is offline
post #2 of 7 Old 10-04-2013, 04:39 PM
Raul@Stealth Automotive's Avatar
i prefer the edge insight CTS... you can click on my signature picture to see some setups.. but for a 6.0L i highly recommend the insight CS or CTS because you can pretty much read everything you need off of 1 unit...
Raul@Stealth Automotive is offline
post #3 of 7 Old 10-04-2013, 04:49 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
You have several choices, depending on what device you may own and how much you want to spend.
Here is a good link.
Write Up: Monitoring the 6.0L PSD.
Edge Insight CS/CTS will be your most expensive if you get the EGT and Fuel psi upgrades. DashBoss for iPad/Itouch/iPhone will run you around $300 with EGT and fuel psi. ScangaugeII will be $120-$160 but you will need to buy separate analog EGT and fuel psi gauges. The cheapest is Torque app for android devices, but you will need to buy separate analog EGT and fuel psi.
Sent from AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 7 Old 10-05-2013, 11:21 AM Thread Starter
ok will check those out thank you for your time
rolin17 is offline
post #5 of 7 Old 10-05-2013, 04:46 PM
c dog's Avatar
I have te SCT livewire. I thought I would like that being a all in one. Well I'm switching to a 4 pod gauge pillar mount to monitor ECT, EOT, EGT & Tranny temp. The SCT is bulky and not as clean looking
c dog is offline
post #6 of 7 Old 10-09-2013, 09:25 AM
DieselManor's Avatar
If you want just a decent set of "hard" gauges, you can take a look here at our most popular set-ups.
DIESELMANOR GAUGE KITS for 2003-2007 Ford 6.0L Powerstroke
It should give you a better idea of some of the options avaiable.
Any questions let me know.
David Murphy
DieselManor is offline
post #7 of 7 Old 10-09-2013, 10:05 PM
JustinOOO9's Avatar
Quoted: 468 Post(s)
Garage
as much as i like the edge for monitors it looks bad with all the extentions added to it.
Im gonna run fuel pres, egt, trans temp and boost on a piller and use my edge for oil/ water temp and then for other pids during test, tunes and diagnostics.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
