temperature control not working - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-13-2013, 07:24 PM Thread Starter
Hello I'm new here.
Okay I have a problem. I have read a bunch of stuff about the heater/ac control and blend door.. my blend door works if i shut it by hand with a tool.
so i thought it was the accuator so I took it off it was dirty and i took it apart and used a 9v battery to test the motor it run fine but when i plug it in and turn the temp from cold to hot the motor does not move. is the head unit the problem or is it some kind of reley
thanks for any ideas
Falcon.Recovery is offline
post #2 of 9 Old 09-13-2013, 07:27 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd test to see if the motor is getting voltage and work backwards from there...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 9 Old 09-13-2013, 07:33 PM Thread Starter
okay do know what the voltage should be ? by the way its an 07 F250 6.0 all stock.
except rims and tires
Your sig is slick nice truck
post #4 of 9 Old 09-13-2013, 09:44 PM
Quoted: 8 Post(s)
I'm not sure about the voltage (I'd only be guess.. But probably controlled by ohms not volts) I'd check for both while changing the temperature control knob. If you get neither volts or ohms... I'd follow the wires closer to the relay and recheck... Keep doing (while moving closer to the switch then ecm or fuse panel) that until you get a reading and you should find your problem. Maybe someone can post a wiring diagram for ya. Good luck
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 9 Old 09-14-2013, 03:12 AM
Dont overthink it, just put a blend door actuator on it.
aloveys1 is offline
post #6 of 9 Old 09-14-2013, 09:48 AM
Quoted: 8 Post(s)
I wouldn't just throw parts at anything without determining the problem first, but its your time and money.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 9 Old 09-14-2013, 10:07 AM
Nor would i, but my suggestion comes from 12yrs of working with the ford product. Im not saying that the cause maybe something else, but 99% of the time its the motor. If you lift the motor off while still plugged in and it works and the door is NOT jammed then the motor is too weak to turn the door. These motors usually fail completely, but they can become weak. I proved this with a lock actuator on my wifes escape which appears to have an identical motor inside. It worked fine in my hand but not in the liftgate. It was a part i had to order, so i took it apart, realized i saw the motor at a surplus store, bought it(4 dollars), replaced the motor, reinstalled the actuator and has been working fine.
aloveys1 is offline
post #8 of 9 Old 01-17-2014, 06:30 AM
I have a similar problem. My temperature control will work on heat and if I go to 60* it takes a minute but will start blowing cold air. As soon as I move the temperature to 65* it will start blowing heat again. It's like there is no in between, either full cold or full heat.
2006 F250 King Ranch CC SB
EGR deleted and studded with oem gaskets
Bulletproof Diesel heavy duty oil cooler w/cold weather package
Sinister Coolant Filter
No Limit Polished CAC pipe
Blue spring, degas bottle, and stc fitting upgrades
SCT livewire with Vivian's tunes
natedog82 is offline
post #9 of 9 Old 01-18-2014, 04:44 PM
Im guessing you have EATC. All of the trucks i work on have manual controls. There are a lot more possible causes with EATC. I cant acess Inford on my ipad, but i believe the control head can run self diag and generate codes. Without an IDS you are going to have to swap out "known good parts", if you have access to them. Or get access to the blend door actuator so you can see it and see if its sticking, jumping etc.
aloveys1 is offline
