LED DOME LIGHTS - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 67 Old 08-16-2013, 07:14 PM Thread Starter
05f250harley's Avatar
LED DOME LIGHTS
I want to change my interior dome lights to leds. Has any body done this? What bulbs did you use and were did you get them from?
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #2 of 67 Old 08-17-2013, 12:36 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Lol nope youll be the first bro. Let us know.
yeah people have done it, I have as well. 42mm 5050 festoon is what you want. Buy them from china and get 10 of each. They are cheaper and the same as the USA ones. In the end the all come from china. You will also want the 6 SMD version for the sides of the domes and then for the center bulb you will want the 9 SMD version.
So get 42mm Festoon bulbs in both 6 SMD and 9 SMD. The 6 SMDs are for the map lights ( outer bulb ) and the 9 SMD is for the center bulb
MrOneEyedBoh is offline
post #3 of 67 Old 08-18-2013, 05:40 AM
MikesF350ps's Avatar
Quoted: 5 Post(s)
Garage
I change mine out with Recon. 4 years and still bright
2007 F-350 4X4, 6.0L, Leveled
ARP Studs, OEM Gasket, EGR Delete, Oil Cooler
EGT, Volt, Water and Fuel Pressure Gauges
MBRP Exhaust w/Cat & Muffler Delete
AVH P 3200 BT with Back up Camera & XM Satellite
High Idle Mod, LEDís All Around ,Viair Air System for Air Horns, XDP Coolant filtration
08 Style Mirrors, Tailgate and Bumper, SCT Livewire TS Amerihood Functional Ram Air Hood with Heat Extractions Vents and S&B Cold Intake
2015 Keystone Montana 3791RD 5th Wheel
MikesF350ps is offline
post #4 of 67 Old 12-11-2013, 06:27 AM
Justin39339's Avatar
I know this is a late post but if you are still interested i went to my local electronics store and bought some LED mini light bars for 2$ each and replaced the factory bulbs with them. i got white and they are decently bright and last a long time. Let me know if you want pics.
2006 FX4 Crew cab F250
Bone stock right now
Justin39339 is offline
post #5 of 67 Old 12-13-2013, 09:50 AM
kslongrider's Avatar
Quoted: 2 Post(s)
Pics
Yes, please post a photo. Thanks.
kslongrider is offline
post #6 of 67 Old 12-13-2013, 04:43 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I got mine from DDMTUNING and then grabbed some cheaper ones off eBay. Very bright and have been flawless for a year now
The smaller ones went in the spots for the map lights, the ones you have to turn on and larger one went in dome light
2005 F350 CCLB FX4
ID:	212818   Click image for larger version
2005 F350 CCLB FX4
juniorssrollin is offline
post #7 of 67 Old 12-21-2013, 10:58 AM
I'm looking for some amber dome lights, don't have to be LED but whatever works. LED DOME LIGHTS-imageuploadedbyautoguide1387655880.626174.jpg
Autozone had blue and red but no orange. Anyone know where to get orange?
Sent from AutoGuide.com App
Alpha Male is offline
The Following User Says Thank You to Alpha Male For This Useful Post:
contee (04-07-2014)
post #8 of 67 Old 01-01-2014, 05:27 PM
Guys, what does the 6/9 SMD mean? Is that like how many of the little square light panel looking things there are on each light? Having a hard time finding orange ones, I found some orange ones on eBay but they are 41mm 6 SMD, will those work for the middle bulb and the 2 sides?
post #9 of 67 Old 01-08-2014, 08:28 PM
Quoted: 3 Post(s)
Here are my experiences...
LED Interior Lamp Upgrade
The more LED's you can cram on there, the happier you will be.
I would use minimum 6x5050 SMD LED bulbs. The ones with 9x5050 would be a bit brighter.
I used 39mm for my front map/dome lights, and the center bulb in my rear dome light. The rear map lights however need a little bit bigger bulb, I think. You would probably be good all around with 41mm festoon bulbs.
I bought all mine off Ebay... cheapest place you will find them. They all come from China anyway, so you may as well buy them direct.
Lee
ve7fet is offline
post #10 of 67 Old 01-09-2014, 07:59 AM
Lee
Okay thanks. I've been looking on eBay but can't fine an orange bulb haha. I wanna do orange to match my chicken lights on the outside haha.
