Need A/C Help, any experts?? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 08-05-2013, 04:58 PM Thread Starter
shiprek's Avatar
Question Need A/C Help, any experts??
2004 6.0 PSD F250 Extended cab.
Was traveling to Lexington, KY last week from Indianapolis with A/C on. It worked fine until I crossed the Ohio River. (I am sure this had nothing to do with it....) any way...stopped cooling. Fan speed is on and and seems to work OK, a mechanic friend tested the gas pressures and they seemed to be OK too. I checked the fuses under the steering column and they seem to be fine. Are there any other fuses to check? Has any one else had this problem?
Thx
RW
2004 F250 Lariat/6.0L/SRW/Crewcab/Shortbed FX4
EDGE Evolution CTS
Python 424 Remote Start
Volant Ram Air
RCD-EGR Delete
Cat/Muffler Delete
Rancho RS 5000 Shocks
6.4 Banjo Bolts
Throttle Plate Delete
4" Straight Pipe
Updated to "Blue" Fuel Pressure Spring
DIY Coolant Filter
Caterpillar EC-1 "RED"
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin, 1759
shiprek is offline
post #2 of 24 Old 08-05-2013, 08:56 PM
Same thing happened to me on a120mile trip worked then stopped. Did notice a slight noise in front of truck. Couple days later lost belt. I think compressor clutch seized or lost compressor.
FamExc is offline
post #3 of 24 Old 08-06-2013, 04:49 AM Thread Starter
shiprek's Avatar
Thank you for the quick reply. I am afraid it is the compressor also. I don't hear any strange noises and have been keeping my eye on any signs of wear to the belt.
Regards
EDGE Evolution CTS
Volant Ram Air
RCD-EGR Delete
Cat/Muffler Delete
6.4 Banjo Bolts
4" Straight Pipe
DIY Coolant Filter
shiprek is offline
post #4 of 24 Old 08-06-2013, 09:03 AM
04cr450's Avatar
Did your friend check the refrigerant pressures while the truck/ac was operating? Only reason I ask is if the truck is not cooling, there is no way to check refrigerant pressures correctly unless the compressor is operating. What were the refrigerant pressures?
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 24 Old 08-06-2013, 09:04 AM
04cr450's Avatar
If the compressor was seized- your truck would have a hard time starting as well(almost would sound like you have dead batteries)
bpd
Warren comp trans
04cr450 is offline
post #6 of 24 Old 08-08-2013, 06:09 AM Thread Starter
shiprek's Avatar
A/C on High
Yes he did. We put the A/C on max. and the fan on high. It was a good hot day. He thought for sure he was going to find a low charge but didn't, so we have to look elsewhere.
Thanks for the response.
RW
EDGE Evolution CTS
Volant Ram Air
RCD-EGR Delete
Cat/Muffler Delete
6.4 Banjo Bolts
4" Straight Pipe
DIY Coolant Filter
shiprek is offline
post #7 of 24 Old 08-08-2013, 06:12 AM Thread Starter
shiprek's Avatar
Everything seems to work except the A/C
That is the surprise everything seems to be working correctly. Belts are tight. Pulleys do not seem to have bearing issues, no fuse blown. I am in the process of checking switches in the system to see if they are functioning.
RW
EDGE Evolution CTS
Volant Ram Air
RCD-EGR Delete
Cat/Muffler Delete
6.4 Banjo Bolts
4" Straight Pipe
DIY Coolant Filter
shiprek is offline
post #8 of 24 Old 08-08-2013, 10:24 AM
astroinhouston's Avatar
When you say your compressor was operating you do mean the clutch was engaged, correct?
If the clutch is engaged, no fuses are blown, and everything else is working, I would think you are leaking freon somehow (though if it does get too low the clutch will not turn) or you have clogged orifice tube. What were the gauge readings?
SOLD (and regretting it everyday since)
2006 King Ranch Long Box
DieselSite Coolant Filter
SCT w/custom tunes
4" Magnaflow Straight Pipe
Edge CTS w/EGT
Bilstein 5100's
astroinhouston is offline
post #9 of 24 Old 08-08-2013, 10:56 AM
bubmiller's Avatar
Check your lines on the passenger's side of the engine bay. Should be two large lines into the top of a "can" (filter). Feel them (with AC running) to see whether either of them is cool to the touch. The small line runs right past the filter. It has a plastic clip over a push-to-connect fitting. It should be ambient temp. or warmer on the front side of the connector, and cool on the back side.
Sorry, that's about as accurate as I can get without knowing the pressures. If you can let me know what you find I might be able to help narrow it down.
06 F250 CCLB
Bulletproof FICM
Sinister EGR Delete
Pypes Exhaust
ARP studs
SCT X3 w/Pro Racer
bubmiller is offline
post #10 of 24 Old 08-08-2013, 12:15 PM
ngaraiderman's Avatar
Not to hi jack his thread, OK I mean to hijack his thread. Mine is doing the same thing.
Its 85 outside currently. Mine will blow slightly cool sometimes then other times it will blow warm. My compressor is also working. I just replaced the a/c pressure switch and have even tried straight wiring the switch to verify compressor was working. Mg pressure is ~340psi. It was low when I got the truck and had to put a large bottle of sub-zero in it from auto zone. My line does get pretty cool on right side of engine bay but it is no where as cold as the wife's table or my work civic is. Not sure what else to look at and had rather do the work myself than have to take to the shop? Any suggestions? I am leaning towards a clogged orrifice also. Also do our trucks have a cabin filter?
2007 F250 crew cab 6.0 4x4.
Any help is appreciated
ngaraiderman is offline
Tags
a/c , air conditioner , cooling
