6.0 rear window - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-18-2013, 08:26 PM Thread Starter
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 476 Post(s)
6.0 rear window
I know its probably on here somewhere, but my power rear window is sticking. Is there a fix for this? WD 40 is my first idea, but your thoughts?
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #2 of 12 Old 05-19-2013, 08:45 AM
TGauger's Avatar
Mine is doing the same thing. I goes about 2 inches and then slows way down for an inch, and stop. I was worried that the wd-40 would eventually get gummy with dirt dust. Subscribed!
05 F-350 CCLB, Harley Davidson Edition
TGauger is offline
post #3 of 12 Old 05-19-2013, 01:11 PM
yea all you have to do is lube it with whatever you want. Then just work it back and forth a bit and good as new. Thats what I did to mine
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
post #4 of 12 Old 05-19-2013, 06:11 PM
Diesel is Power!!!
bigmic's Avatar
Quoted: 2 Post(s)
Try this: 1 small spray bottle, Rubbing alcohol and some dry graphite mix together and spray in the track. The alcohol solution cleans and lubes and doesn't leave a greasy mess.
06 CC 4X4 King Ranch
225k + miles
Reman Motor @ 173K (Problem existed b4 I bought it)
SCT Dash Scan
SCT Livewire/EGT Kit
TSD SPD and TDP Extreme tuned
Glowshift Fuel Gauge
ARP Studs
FelPro Head Gaskets
Warren 155cc/stock injectors
Cat Delete
EGR Delete
Update STC fitting
Blue Fuel Spring
New oil cooler
New Turbo
Stand Pipes
Sinister Coolant Filter
ELC Coolant
bigmic is offline
post #5 of 12 Old 05-19-2013, 06:28 PM
TGauger's Avatar
So i ended up using a wd40 pen and just kept working it back and forth on the little cable and track and moving the window open and closed. Paper towel twisted to a point worked to clean the crud out. Now the window works like new!
TGauger is offline
post #6 of 12 Old 05-19-2013, 06:38 PM
my0460's Avatar
Mine is loose in its track. I have to work it back and forth sometimes. It will try to tilt in its track. Any ideas on what to use to re glue it in place?
04,cc,sb,4x4.
egr. delete
sctx3
over mirror gauges.
mbrp 4" no cat,no muffler.
my0460 is offline
post #7 of 12 Old 05-19-2013, 08:44 PM
585Amarillo's Avatar
wd40 on mine works great
K&N Intake
MBRP 4" Turboback
Silverline 6" Black Aussie Stacks
Zoodad Mod
Ford Updated parts
BPD FICM
Blue Fuel Pressure Spring
ARP Head-studs
Stock Injectors?
AirDog 165 Fuel pump
EGR Delete
SCT Custom Tuner By Inovative Diesel 5 tunes
10" Lift
37" Toyo Open Country M/T
4.56 Gears
18" XD Thump Black Wheels
6.4 Banjo Bolts
Revised Ford Parts
Custom sound system
Glowshift Gauges Trans.Temp., EGT, Fuel Pressure
585Amarillo is offline
post #8 of 12 Old 08-12-2013, 02:08 PM
Rollincoal941's Avatar
Have a person operate the button while you wd40 the track that seem to solve my problem when my window was sticking
06 f250 kingranch FX4
Arp head studs oem gasket Airraid intake
egr delete byebye 5inch mbrp turbo back 8inch mbrp tip Sinister coolant filter elc coolant updated stc fitting stand pipes dummy plugs new oem injectors 6.4 banjo bolts blue spring Sct livewire ts with Vivian looney wild tony wildman extreme Super panty dropper
8inch procomp lift 4inch with airbags in the rear
Custom headlight painted kr red hids and leds everywhere! 692 moto metal with 37s mud grapplers
Rollincoal941 is offline
post #9 of 12 Old 10-19-2013, 12:04 PM
soccerman's Avatar
I use a liquid graphite which dries right away. Got it from a bicycle shop which they use on the brake and shifter cables. Do it every couple of months. Fine it better then WD40
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #10 of 12 Old 11-26-2013, 11:21 PM
Blknite23's Avatar
WD-40 FTW!! i do mine every month... along with the cables
2006 CrewCab F250..
*Banks Big Hoss kit, Looney Wild, Studs, 6" with 37's other odds and ends
Blknite23 is offline
