Height adjustable pedals alreary installed?
996 views 1 reply 2 participants last post by  GregsSD
#1 ·
Hi,
Did all 6.0's come ready with height adjustable pedals? My 2007 has the blank switch to the left of the steering wheel. When I popped the switch out, there was a whole wire harness attached to it. Could this be for anything else other than the pedals?
#2 ·
The adjustable pedals were not standard, they had to be ordered on the truck.
It could be that the wiring harness is there, just not hooked to anything, look under your dash at where the pedals mount and you can see if they are mounted on the power slide assemblies or not.
