Weird interior cab leak??? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-23-2013, 12:13 PM Thread Starter
Hey guys,
I did some searching and couldn't find anything except for some traditional cab leak situations. But I was getting into my 04 today and I noticed my driver side floor mat was absolutely soaked. It had been raining a little bit on and off all morning. Of course my feet were wet getting into the truck in the morning, but I didn't notice anything soaked then, and my feet were no where near wet enough to soak the carpet. Heres the kicker, to the best of my knowledge, every other time it has rained, its been dry as usual. Even harder rains than this one. I got to looking, and a couple drops were coming off the bottom of the dash. I got to feeling around, and as far as I could tell, it seemed dry underneath the dash. Nothing on the dash has shorted out or quit working either. Then, I took out my floor mat and there was a wet spot about the size of a dinner plate between the seat and my pedals. But, it was basically dry all around the cab corners and everywhere else. Anyone ever seen anything like this? Ive seen older trucks do stuff like this or if water from the AC is draining into the cab, but that's on the passenger side. But this isn't like that. Anyone have any explanation, solutions, or input?
Steven- 2004 6.0L crew cab shortbed FX4 King Ranch EGR deleted, billet oil cooler, 6 inch Skyjacker lift, Procomp alloys, Nitto Terra Grapplers
Wassilak is offline
post #2 of 6 Old 04-28-2013, 09:07 PM
redneck6.0's Avatar
Get underneath and see if there is a rubber grommet of some sort leaking
2006 f250 ccsb
Junk k&n intake
Mbrp tb
Egr delete
blue sprin
Oil bypass
Sinister coolant filter
Atlas 40 tuned ficm
6"bds w/ procomp prorunners
18x10 moto metal 962
325/65/18 fierce attitude
Harley heads
Rigid duallys
Horn blasters
redneck6.0 is offline
post #3 of 6 Old 10-21-2013, 11:26 AM
Texas Proud
charlie.thomas's Avatar
If you have a sunroof it is most likely leaking on the driver side corner of the sunroof toward the front of the truck, mine does it when it is sitting flat. It leaks in through that corner and it runs down the driver pillar onto the floor. Just found mine the other day and still need to fix it. You can park your truck where the front sits a little higher and it won't do it but if you park level or where the truck slants forward it will leak in, after a real hard rain it had my headliner wet around that corner of the sunroof and reached my finger in the crack and could feel the water dripping in. I'd check that if you haven't fixed it by now.
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #4 of 6 Old 10-25-2013, 03:43 PM
Quoted: 8 Post(s)
I had that same problem. Had to replace a rivet and do some re-sealing.
Sent from AutoGuide.com App
- Scott -
2004 F-350 Lariat CC DRW
New Blackwater Engines Long Block @ 126,000 miles
w/ ARP Head Studs and OEM Gaskets
EGR Delete
Straight 4" Exhaust, Turbo Back
Blue Spring Upgrade
s20055 is offline
post #5 of 6 Old 10-28-2013, 03:28 AM
Texas Proud
What rivet is it and what did you have to reseal? Just wondering because I'd like to fix mine
5" AFE air intake
Blue Spring Mod
High Idle Mod
ARP Head studs
And other goodies
post #6 of 6 Old 10-29-2013, 07:45 PM
Quoted: 8 Post(s)
The rivet held the track assembly together. It was in the front right corner. It had come loose and water was seeping through. I drilled it out and applied sealant between the two pieces, then put another rivet in. Like new!
- Scott -
EGR Delete
Blue Spring Upgrade
s20055 is offline
