Door squeaking - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-16-2013, 03:45 AM Thread Starter
Door squeaking
Keep hearing a squeaking noise on the driver side doors when going over bumps. I can pin point exactly where it's comming from and it's driving me crazy has anyone had this happen? Extended cab
Lennyk83 is offline
post #2 of 12 Old 04-16-2013, 06:01 PM
elchaseo's Avatar
Quoted: 8 Post(s)
Is it almost like a chattering noise?
2015 F250 Lariat- CAI, CCV Reroute....more to come
elchaseo is offline
post #3 of 12 Old 04-16-2013, 06:08 PM Thread Starter
Yes! I'm starting to feel like its only when it's cooler temps like in the am and at night so I'm guessing the rubber seal possibly contrasting? It's hard to tell while I'm driving and trying to listen where it's comming from. Have to have someone else drive it
Lennyk83 is offline
post #4 of 12 Old 04-16-2013, 08:12 PM
michaelbyoung's Avatar
Mine just started squeaking. It's annoying. I am going to do the weatherstrip mod when I get a chance and see if that helps.
Sent from AutoGuide.com App
2006 F-350 Lariat Crew Cab Long Bed 6.0 Diesel
Chrome Pkg All Stock 185,000 miles
B&W Turnover Gooseneck w/ 5th wheel companion
ScanguageII High idle mod On board air
2011 Jumpseat Gutted Cat Mikeymod muffler
EGR delete CCV mod EC1 coolant Zoodad mod
2000 F-250 Lariat Crew Cab Short Bed 7.3 Diesel ***STOLEN*** 11/19/2011
4" Rancho Lift
215,000 miles
afe intake
4"turbo-back
IAH delete
Foil Delete
michaelbyoung is offline
post #5 of 12 Old 05-21-2013, 06:23 PM
elchaseo's Avatar
Quoted: 8 Post(s)
Don't know if you guys figured yours out but I found my culprit. It was the thing that holds the seatbelt on the pillar. Bahaha total facepalm moment.
elchaseo is offline
post #6 of 12 Old 05-21-2013, 06:33 PM Thread Starter
I had a feeling it was comming from up there. Did you find a way to fix it? I haven't really looked at it
Lennyk83 is offline
post #7 of 12 Old 05-22-2013, 01:29 AM
elchaseo's Avatar
Quoted: 8 Post(s)
Honestly I've been so busy lately and driving a different vehicle that I haven't had a chance to do anything about it. But I'm thinking a shot of wd40 on the roller and the pivot point would quiet her down.
elchaseo is offline
post #8 of 12 Old 09-23-2013, 06:31 AM
I know I'm kinda late on this but I have this problem on both passenger and driver side. It's not my seat belts tho as they are in the shoulder of my seat and not the door. Squeaking chattering sound like you're talkin about. Any ideas? Thanks
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #9 of 12 Old 11-23-2013, 01:44 PM
x96535's Avatar
I'm sure there's several different things that could create the chatter noise. Mine was in my rear driver's door and was driving me crazy. I took the door panel off today and sprayed the mechanism that the horizontal rod attached to the door lock connected into with WD-40. I then took some leftover 3/8" vinyl tubing from my door seal mod (that mod obviously didn't make the door squeaking stop) and cut a vertical line down the tubing. I then wrapped the vinyl tubing around the horizontal and vertical rod for the door lock anywhere that it could make contact with the metal door. I put the door panel back on and went for a drive. Not a peep coming from the door anymore!!!
x96535 is offline
post #10 of 12 Old 11-25-2013, 06:28 AM
Joeshu1000's Avatar
I have the same door squeak that you guys are talking about. On gravel roads I could actually feel the door moving, just the slightest bit. As a test, I wrapped some electric tape on the striker plate, where the door latch latches on, and the noise went away, well until the tape wore off from opening and closing the door. I need to replace the striker plate, just haven't done it. Hope this helps or makes sense. LOL...
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
