Disable seatbelt reminder. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-09-2013, 06:20 PM Thread Starter
valhalla1's Avatar
How do I disable the seatbelt reminder on my 2005 F-350?
valhalla1 is offline
post #2 of 15 Old 04-09-2013, 07:58 PM
USAFBowman's Avatar
Wear your seatbelt??
There should be a operation listed in the owners manual to disable it.
Here is what I found on a google search for a 2005 super duty...
Preparation
Before deactivating/activating the Belt-Minder®, apply the parking brake.
Place the gearshift in the PARK (P) position (automatic transmission) or the NEUTRAL (N) position (manual transmission).
Place the ignition switch in the OFF position.
Close all the vehicle doors.
Unbuckle the driver safety belt.
Place the headlamp switch in the OFF position.
Deactivating/Activating
Turn the ignition switch to the RUN position (do not start the engine).
Wait until the safety belt warning indicator turns off (approximately 1 minute).
NOTE: Step 3 must be completed within 50 seconds after the safety belt warning indicator turns off.
At a moderate rate, buckle then unbuckle the driver safety belt 9 times, ending with the safety belt in the unbuckled state.
After this step, the safety belt warning indicator illuminates for 3 seconds.
NOTE: The buckle/unbuckle sequence may not be counted if completed too fast. Wait approximately 2 seconds after each sequence.
Within 10 seconds after the safety belt warning indicator turns off, buckle then unbuckle the safety belt.
This disables the Belt-Minder® feature, if it is currently enabled. As confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds.
This enables the Belt-Minder® feature, if it is currently disabled. As confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds followed by another flash sequence of 4 times per second for 3 seconds.
After confirmation, the deactivation/activation procedure is complete.
Or you can unplug the harness... that should work too
USAFBowman is offline
post #3 of 15 Old 04-12-2013, 01:04 PM Thread Starter
valhalla1's Avatar
Talking
Man I really appreciate it! I do alot of drive two minutes get out and work for ten on my prorerty and this was getting annoying on my new to me truck!!
post #4 of 15 Old 04-12-2013, 06:42 PM
Fox Hunt's Avatar
Quoted: 26 Post(s)
thats what i did, that way you dont have to do that whole process again whenever you batteries die or you disconnect them
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #5 of 15 Old 04-14-2013, 10:28 AM
hogasm's Avatar
I just went to the dealership and they gave me a 6" belt extension. Plug it in and no more annoying buzzers or lights
I'd rather be fishing
hogasm is offline
post #6 of 15 Old 04-14-2013, 10:44 AM
onebadcoastie's Avatar
Quoted: 10 Post(s)
Unplugging the harness takes less time than reading about anything. lol
Shack
2016 F-350 CC Dually
2005 F250 CC FX4….SOLD
onebadcoastie is offline
post #7 of 15 Old 04-14-2013, 02:15 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I have had my batteries out once and disconnected numerous times.
Never had to re-do the process.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #8 of 15 Old 04-14-2013, 03:02 PM
Fox Hunt's Avatar
Quoted: 26 Post(s)
Huh, well whatever works. We the the process on my dads 06 and he had to redo it after that. We both just have it unplugged now. Its easier to do lol
Sent from AutoGuide.com App
Future Mods:
-Alex
Fox Hunt is offline
post #9 of 15 Old 04-14-2013, 03:03 PM
Koda22's Avatar
Quoted: 5 Post(s)
How do you unplug it? And if I do unplug it does it effect anything else?
Koda22 is offline
post #10 of 15 Old 04-14-2013, 03:47 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Lop u just unplug it by the seatbelt..done, and nothing special to do or anything
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
