| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
Can I add 2012 AC/Heated seats to a 2004 Excursion
Like the subject says. Can it be done and will the heat and AC work?
People have swapped the seats before, I don't think it's much hassle. Assuming you have the plugs for the heating system it would be easy to wire otherwise you need to wire it in yourself with a power source.
For the ac no you would need to plumb ac ports up to and into your seat which would be extremely hard |
I believe it is just circulating air. They are still awesome! Used them today in the heat wave we are having in Utah. It got above 70... |
Maybe it is? I could be very wrong.
Some vehicles use the actual hvac cold air. It's just hard to tell which do! Last edited by kornfanjoe; 03-15-2013 at 01:54 AM. |
Re: Can I add 2012 AC/Heated seats to a 2004 Excursion
I realize this is for a ford forum. Don't hate. But my dad has a 2012 Denali dmax. And the seats have built in ac units. Its all a self contained unit. Yes I realize ford and gmc r different. Just saying. They do make seats with built in ac units
Sent from my VS930 4G using AutoGuide.Com Free App |
I am pretty sure the seats are self contained with the cooling and heating units. What I'm trying to figure out is if they can just be hooked up to power and ground with a switch or do they need to be run through a PCM that would only be in a 2012-2013 250 and not in my vehicle?
Sub'd. This would be the best mod ever here in FL. Hope you get it worked out.
If it is just the heating coils and a blower motor, I would think you would be able to hard wire it your self. I know these have to be connected to the computer somehow, becuase they turn on and off automatically. When you remote start your truck, ect... |
Lol, well at least if i leave the ac on when i use my remote start itll cool the truck... just not my a55...
