Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
  #11 (permalink)
Old 11-22-2007, 06:41 AM
JimboJames JimboJames is offline
I check the windshield with warm soapy water and lots of compressed air. The windshield is not the problem. I need to look else where now. A guy at a body shop told be that the drains for the sunroof get clogged and build up water at the top of the pillars. That is where I am seeing the water. I just need to find the drains to blow them out and see that fixes it.
  #12 (permalink)
Old 11-22-2007, 06:51 AM
06TWO50Diesel 06TWO50Diesel is offline
Not to hijack- i was hoping you would write about your rear window. My rear most window (with slider) had mold on it one day... WTC?!
maybe I'll find an answer on this post
  #13 (permalink)
Old 11-22-2007, 06:54 AM
Rodslinger Rodslinger is offline
Gun Nut
A bit of a long shot here but if you PM me your VIN I'll run an Oasis Report for you to see if it's been into the dealer for this problem before. Maybe the sunroof or windshield has had issues in the past when it was under warranty.
ETA: Oh and WELCOME to the ORG!
  #14 (permalink)
Old 11-22-2007, 06:56 AM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
Wash the truck. Go to one of them drive through car washes. When you go through it look around the area where you see evidence of a water leak. Another thing you can do is do this with the headliner removed. I have found many water leaks like this.
  #15 (permalink)
Old 11-22-2007, 07:05 AM
dieseldan2005 dieseldan2005 is offline
If it aint a CAT itsa DOG
My parents have a 2005 F350 and it leaked from day one so they have had it re-sealed 3 different times. It seems to be good now. My wife and I have a 2005 Ford five hundred and we have also had to reseal the windshield 2 times from when we bought it with 43k on it. The rubber gasket just kept pulling out, especially when going through car washes. 2nd time it happened i fixed it with true super glue and its stiffer than the rest of the gasket. Just hope we don't have to replace the windshield someday. Poor glass guy is gonna have fun
  #16 (permalink)
Old 11-22-2007, 07:13 AM
Jon Jon is offline
The MN Kid!
Quick check
There are sun roof drains that run down the pilars and center support between the doors, one of them might have come loose.
  #17 (permalink)
Old 11-22-2007, 07:14 AM
Jon Jon is offline
The MN Kid!
Oh
One other trick turn the ac on high and on reserculate and go around the suspectd external leak area with a spray bottle full of soapy water. If its an external leak "not the drain tubes" it should bubble up.
  #18 (permalink)
Old 11-22-2007, 10:35 AM
I like I said before I have check all the externals with soapy water and a air nozzle. the windshield does not leak.
  #19 (permalink)
Old 06-17-2008, 08:55 AM
1donos 1donos is offline
water leak
I have seen water leak through the cab lights on numerous occassions. If you have them I would start there.
  #20 (permalink)
Old 06-17-2008, 09:57 AM
Diesel Monkey Diesel Monkey is offline
I just replaced the sunroof drains, not difficult. Hardest part is pulling down the headliner in one piece. The drain tubes were undersize or shrunk, got hard and cracked. The drains were plugged with dead bugs and dirt. Took a little time regluing the headliner a little at a time. Now it drains without a problem.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
