Lariat power windows quit working - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-16-2012, 07:07 PM Thread Starter
CassMori's Avatar
First off, this is a 2005 F350 Lariat Crew Cab.
Last night, the power windows worked fine. Got in the truck tonight, and all five windows (four doors & sliding rear) are non-functional. Checked the switches on all doors (and the dash switch for the rear window), none do anything. Everything else (radio, interior lights, cluster, etc.) are working normally.
Pulled the circuit breaker, stuck a 30a fuse in just to check, still nothing. When ignition is on, I have no power in the socket for the circuit breaker. Per my Haynes manual, the power for the windows uses a light blue wire with a black stripe - I found two of these entering the rear of the fuse box, neither have power (ignition on). I would have checked the power source for the blue/black wire, but I'm not sure where it originates.
I removed a malfunctioning Viper alarm last night, but the windows (driver's, at least) were working after that.
Anyone have any ideas as to what I should check next?
2005 F350 SD Crew Long Bed FX4 Dually Lariat, 6.0L PSD. 4" catback, 3.5" dp & cat delete, Sinister Diesel coolant filter; Bulletproof EGR cooler, ARP studs. 380k+
CassMori is offline
post #2 of 6 Old 07-17-2012, 12:43 PM Thread Starter
CassMori's Avatar
I've done some further checking today, and I have power to the Delayed Accessory relay - I can jumper from that power to the output terminal the circuit breaker plugs into, and the windows will work. So it seems the power is not being transferred for some reason from the relay to the circuit breaker. I have swapped the relay for another, with no improvement.
Also, I noticed that my opera lights (front and rear) are not working, but I'm not certain if this is related.
I checked with a friend who is a Super Duty tech at a local Ford dealership, he said that he's seen the circuit boards in the fuse box itself go bad. Anyone else heard of this before?
CassMori is offline
post #3 of 6 Old 07-17-2012, 05:58 PM Thread Starter
CassMori's Avatar
Did some more digging in the fuse box/wiring, found the fuse box is fine, but I'm not getting power to the control circuit for the relay. Not sure which wire (solid light blue & green w/yellow) is power and which is ground, neither have power with ignition on.
I guess at this point I'm probably going to need a wiring diagram for the dash/ignition switch if someone may have one, or if someone can tell me which of the two wires is power, and where it gets that power?
CassMori is offline
post #4 of 6 Old 02-11-2015, 02:42 PM
Ez
Quoted: 23 Post(s)
Garage
any update on this, having similar issue
2003 6.0
SoBStevens is offline
post #5 of 6 Old 02-11-2015, 04:34 PM Thread Starter
CassMori's Avatar
My problem turned out to be a section of the instrument cluster circuit board that was burnt out. I re-connected a couple of jumper wires the previous owner had installed, that had been disconnected when I removed the alarm. I don't have the truck any more, and it's been a while, but I believe the two wires I mentioned above were the ones with the jumpers (one power, one ground, iirc). In my case, the only other way to fix it would have been to install a new cluster.
CassMori is offline
post #6 of 6 Old 02-11-2015, 06:21 PM
Supporting Vendor
CircuitBoardMedics's Avatar
Quoted: 9 Post(s)
This is a textbook description of a faulty instrument cluster. We can take care of that for you with no need for any programming. Your mileage will remain correct as well. Please find complete details here:
http://circuitboardmedics.com/ford-s...luster-repair/
Please feel free to contact us at 800-547-2049 if you have any questions.
CircuitBoardMedics is offline
The Following User Says Thank You to CircuitBoardMedics For This Useful Post:
Heavy_GD (02-11-2015)
