| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
Sub Feedback Issue
Not sure if this is where i should post this...
This weekend i did a little sound upgrade, didn't want anything obnoxious. I did a 1k watt amp(over kill ) , and 2 8" kickers behind my back seat( W tweeters). running my factory radio (well actually a Mach 300) same thing. Anyway im getting this weird feedback issue. (sounds like this) any ideas? I need to take some pics tomorrow |
reground your cb and your radio will probly take care of it.
i could never get my cb to quit doing it. i no longer have a cb anyway. are you thinking its a ground issue with the amp?
Bump.
Sent from my iPhone |
Did you run all wires together? As in your main power cable next to the RCA cables? Is so that's probably your feedback. The main cable and remote wire need to run together while the RCA cables need to run at least 12 inches away from the others. The current running through your power wires is picked up through the RCAs and heard as feedback in the speaks.
that makes sense. tomorrow morning ill run my RCA's on the opposite side of the truck. give that a try
Let me know if it works. Should do the trick. If not I have one more trick for ya
This was the problem
![]() Moved it to the other side of the truck. Sounds so much better. Thanks! Sent from my iPhone |
Glad it worked!
Bingo!
That's what the problem was on my Mustang a while back, always keep audio/data separate from power ![]() Glad its working though. |
