Interior Light Bulb Numbers - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-08-2012, 05:24 PM Thread Starter
MGFISH's Avatar
Question Interior Light Bulb Numbers
Okay, there are about 52 pages in this forum alone. I made it through the first 3 pages before I decided to just make a new post.
I have a 2006 King Ranch with the moon roof. Two front map lights. And a rear dome light with two switch activated map lights.
I know the dome light size is 578.
What I don't know are the sizes of the 4 map lights. I would figure they are probably 194's....they're pretty common bulbs...but not certain.
Just wanted to find out for sure what size the bulbs are.
2006 F250 King Ranch
MGFISH is offline
post #2 of 18 Old 06-08-2012, 05:32 PM
back to business
07OUTLAW's Avatar
I have a similar interior setup. Lariat w/ sunroof.
Front map lights/dome, rear dome and rear map lights are all 578 festoon bulbs. I'd suggest going to LED's . I have red in the dome lights and white in the map lights and lighted vanity mirrors. The red looks killer with my interior, but white (which I had before) looks great too.
Just pop the covers off and take a look
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #3 of 18 Old 06-08-2012, 05:41 PM Thread Starter
MGFISH's Avatar
I don't have an actual dome light up front, just the two map lights.
And 578 bulbs would seem pretty large for the map lights....
I'm actually working on swapping to LED's, this is why I'm trying to find out the numbers.
Right now, I need 6 - 194 bulbs for the exterior (license plate and running boards)
MGFISH is offline
post #4 of 18 Old 06-08-2012, 07:04 PM Thread Starter
MGFISH's Avatar
well, I went on fordparts.com, just to see if they'd have info. Looks like you were right outlaw...all the same bulbs
MGFISH is offline
post #5 of 18 Old 06-09-2012, 07:34 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Make sure you get LEDs that offer direct, straight light. The light housing in the truck is designed to take the 360 degrees of light from the Festoon and focus it through a light tunnel. That tunnel provideds a problem for regular, wide beam LED Festoons. So that's why you need a LED Festoon with direct light instead of a wide beam, flood light. I just went through this and ended up with LEDs in the domes and the regular halogen in the map lights. I'll keep searching for a direct beam Festoon LED though.
Here, I pulled one off and took some pics. Hopefully, you can understand what I'm taliking about.
Back side. Shows the reflector that wraps around the Festoon bulb
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 18 Old 06-09-2012, 08:03 AM Thread Starter
MGFISH's Avatar
thanks for the info. I'll certainly keep that in mind. and thanks for the pics....definitely easier to grasp how the lights are setup
MGFISH is offline
post #7 of 18 Old 06-09-2012, 08:14 AM
dfuzz78's Avatar
You're Welcome! Sometimes it's easier to understand with a pic!
Denis "Lt. Sled"
dfuzz78 is offline
post #8 of 18 Old 06-09-2012, 08:19 AM Thread Starter
MGFISH's Avatar
Did you try aiming the lights into the reflector? wondering if that might help the issue. I haven't seen a festoon bulb with a 360 degree pattern yet. I'd be kind of bummed to have LED's...except for the map lights...I'm picky like that
MGFISH is offline
post #9 of 18 Old 06-09-2012, 08:24 AM
dfuzz78's Avatar
Yeah, tried that but light doesn't go through circuitboard very well... There just isn't enough room in there for light to bounce around. I was really bummed when the LEDs provided no direct light in the map light location. I know they make something, just haven't looked that hard yet. Other things get in the way...
Denis "Lt. Sled"
dfuzz78 is offline
post #10 of 18 Old 06-09-2012, 08:38 AM Thread Starter
MGFISH's Avatar
found a site. but, they list the sizes in mm....any idea what the length in mm those bulbs are?
Festoon Dome Lights
MGFISH is offline
