Gear Shift Indicator Broken? - Ford Powerstroke Diesel Forum
Old 05-18-2012, 03:14 AM
Hey guys, I was wondering if anyone knows any fixes for a broken gear shift indicator. The little orange pin doesn't move at all when I change gears its pegged all the way to the right all the time.
I have searched and saw threads about adjusting the pin where it would move when changing gears, but none about fixing a broken one.
Any ideas?
Old 05-18-2012, 03:34 AM
A new one there easy to change pull cluster unhook from back of cluster then there's a piece on steering column that's were its broke got one bolt then pull the cable off the hook under the dash then replace
Old 05-18-2012, 03:37 AM
What do you think the chances are it just came unhooked? It wouldn't shift if that were the case correct?
Old 05-18-2012, 05:51 AM
Very un likely there very common to be broke and is 99 out of 100 is broke on the plastic piece that bolts on the steering column iv changed too many ha but if u get under there and look u can see if that piece is broke there or unhooked
Old 05-19-2012, 10:22 AM
It ended up being the loop was broken. Whoever the idiot was that assembled these things didn't strip the red coating off the little cable, so the cable slipped out coating and the little brass clamp that creates the loop. So I rigged something up with a zip tie and an electrical connector.
Old 05-19-2012, 12:54 PM
Cool lucky ha glad u got if fig out and some redneck injenuity fixs anything ha
