Removing Headliner Tips - Ford Powerstroke Diesel Forum
Old 04-02-2012, 08:01 PM
i am going to be removing my headliner too install new led clearance light if anybody can tell me how to remove it and some tips it would be great thanks
Old 04-02-2012, 10:56 PM
I believe removing it actually requires removing the either the windshield or back window. You might be able to get away with just dropping it down, but i'm not sure. i had to drop down the back to install some NMO antenna mounts. It just required unbolting the lights, handles, and pulling away some of the plastic trim pieces.
Old 04-02-2012, 11:17 PM
Yeah it's much easier to drop it down than to actually remove it. It is possible, but you have to be careful not to fold it so it will leave a crease in it. Carefully remove all of your trim. It's pretty straight forward.
Old 04-03-2012, 04:52 AM
Suck, Squish, Bang, Blow!
Pull the A & B pillar trim and the visors. To pull the B pillar, you'll have to remove the seatbelt which is a large size Torx, don't remember the size off hand. Maybe 55 or 60... Next, pull the domelight. Then the headliner will fall. Good Luck!
