| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
Moonroof Parts Source
Does anyone know where to get parts for the moonroofs. I have a 2005 an d the guides in the track are broken. Called local dealer they only showed replacement motors and complete assembly. All of my stuff is good except the broken piece. Any help or a diagram would be appreciated.
Nobodys ever worked on these ?
i need new seals because mine has a little leak thats starting to stain my headliner around the edge of the moonroof i would like to know where to get parts too
You can get a few from the dealer. Ive got a diagram and it looks like you can get the seals for the glass.
thanks after searching around i found a place to buy pretty much everything i think but i think ill start with cleaning out my drain tubes....does your diagram show where the tubes come out at?
They come down your pillars front and back . You buying used or new parts?
new parts from here: Ford - F250 - 2006 - CAB - Sunroof - Ford Parts Up To 30% Off
I found a guy that sells kits for these sunroofs. He goes by sunroof doctor, sells on ebay and has a site. The kit that I bought has all the wear parts and liftarms. Great kit if you need parts most are not available from ford.
Sent from my DROIDX using AutoGuide.Com Free App |
do you need to remove the headliner to give some maintenance to the sunroof?
