Anyone using a CTS dash pod, need some help? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-03-2012, 02:57 PM Thread Starter
baycountry16's Avatar
So I have a CTS and dash pod and really do like the looks of it. Problem is the Velcro and 3m adhesive tabs it came with suck! A few of them keep coming loose and pod keeps coming loose from dash. Does anyone know of any tricks or additional ways to secure the pod more securely to the dash? Any help is appreciated as always!
2006 F-250 King Ranch Crew Cab Long Bed
146,000 miles and counting....
Mods so far....More to come
ARP Head Studs
Custom Diesel EGR Delete
4" MBRP Turbo Back Straight Piped Exhaust
Zerex CAT ELC Coolant
Updated STC Fitting, Turbo Feed and Drain Tube
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
Edge expandable EGT Probe
Edge Fuel Pressure Sensor
SES SS Billet Grille Inserts
Recon Smoked Cab Light Covers
baycountry16 is offline
post #2 of 7 Old 03-03-2012, 03:06 PM
majek5's Avatar
I have an 06 KR too. I had to reshape the pod to fit correctly. Once I did that...fits great and stays put using just the stuff they sent with the pod. I rebent a few of them, but it is rock solid.
Did you have a clearance issue with the grab bar? Without doing some modifing, mine would not fit.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #3 of 7 Old 03-03-2012, 03:17 PM Thread Starter
Not too bad, the CTS kind of wedges in there against the grab handle. The main tab I'm having issues with sticking is the one on inner left side of pod. That seems to be where it keeps coming loose
ARP Head Studs
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
post #4 of 7 Old 03-04-2012, 05:17 AM
Heathrm's Avatar
I also had to re-shape my dash mount a little. I actually went too far with the first one and called edge about it. Pretty much asking why we needed to modify something they said was for the KR and X's specifically. Too my surprise, they sent me another one. I used almost all of the pieces and plastic-velcro from both of them. My mount does not move at all.
2004 Excursion Limited, 211,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #5 of 7 Old 03-04-2012, 10:03 AM Thread Starter
so really what your saying is that I just need more velcro mounts than the three that came with it to make it more secure. Maybe there is someway I can fab up some more
ARP Head Studs
PMM Coolant Filter
Blue Spring Upgrade
High Idle Mod
Edge Insight CTS
post #6 of 7 Old 03-05-2012, 02:50 AM
Heathrm's Avatar
When I installed mine, two years ago, I have never had a problem with it. I did use some of the extra pieces I had from the first mount kid. I just thought more would be better, and apparently it was/is.
Heathrm is offline
post #7 of 7 Old 03-29-2012, 04:01 AM
RedBKM's Avatar
I tossed the included rigid velcro. I have previous experience with that crap. It works great for the wife's pictures but it doesn't flex enough for automotive use (vibration). Get some industrial quality original velcro and you will be much happier.
Mine just touches the grab handle.
Sent from my SCH-I500 using AutoGuide.Com Free App
2006 F350 PSD Lariat 4x4 SRW, 4" MBRP straight pipe, SCT X3 w/ ID Tunes, Edge Insight CTS, Sinister Coolant Filter, High Idle, Red
2013 F250 6.2L 4x4 (work truck) Factory E-locker, Warn Trans4mer M12000
1995 Mustang Cobra 5.0, Heads, intake, 65mm TB, headers, exhaust, 3.73s, Cobra Rs, 160k trouble-free miles, Red
2011 Mazda Tribute (Ford Escape) 2.5L, 4x4 & 27mpg= Thank you Ford, eBay heated seats, Red
'42 International K1 pickup, Green Diamond I6, 4 on floor, Red
RedBKM is offline
