Dash lights going out - Ford Powerstroke Diesel Forum
Old 02-18-2012, 11:14 AM
The lights behind my speedometer on my 06 are goin out. Are there a bunch of different single bulbs to change or is it like a whole unit to change out? And how hard is it to get to them? Thanks
Sent from my HERO200 using AutoGuide.Com Free
Old 02-21-2012, 04:20 PM
C.B C.B is offline
Hey buddy I too, am facing the same problem. i pulled my dash and tired the old swich one bulb over to the bad spot and found out that it wasnt my bulbs that were bad that cluster still doesnt work. still havent figured out what is really wrong. but ima guess witch ones are out on yours. far right top and bottom lights and the tack is half bright and half dim?
Old 02-21-2012, 04:27 PM
Mine is the speedometer, the numbers from 0-40 are dark
Old 02-21-2012, 04:37 PM
C.B C.B is offline
There is a few 1/4 twist style bulbs, I hope thats all you need. mines not the case. the dash should just pop off start above your radio and just work toward your steering wheel. All the wires will unplug fairly easy. just take your time and undo them all then you need a small 8 mm i think may be smaller and start on your gage cluster just a few screws and two our three plugs and youll have it out. Its really not hard just a little agravating at times. But you should have it out and back in within an hour at the tops.
Old 02-21-2012, 05:06 PM
Powerstroke Techie
I don't think I have ever seen anything other than burned out bulbs.
