| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
08-2010 door panel wiring help guide!!! FINALLY!!
Alright guys, lots of us have wanted to do this upgrade and some of us have, but a lot of folks are worried about the different wiring on the switches for the drivers side windows and the drivers and passenger side door locks. As for the door locks yall are out of luck as pig tails will be required or soldered onto the switch which I dont wanna do. But for the windows on the drivers side heres the information yall need. I have attached pics of before and after on the connections, so the first pics are what your 99-07 connecters will be wired as, the last pics are how the wires need to be for the 08+ connections. The wires are also in different spots in the connectors so you will need to take them apart and put them in the right spot. The green connection that the lock uses will fit in the new window connection spot with the blue one.
Disclaimer. I am retarded and was able to do this with a little patience and a buddy. With this information anyone should be able to do this fairly quickly but incase your truck burns down to the ground or blows up...its not my fault lol just with a volt meter I got this info for the factory wiring and what wires did what: blue connector: black-ground orange/black-down drivers side front white/black-up drivers side front blue/black constant 12v peach/blue-up passenger front white/yellow-down passenger front grey connector yellow/grey-12v constant yellow/black-passenger side rear down black/red-passenger side rear up yellow/blue-drivers side rear up grey/orange drivers side rear down pics to show what a 99-07 will/should look like ![]() ![]() ![]() ![]() ![]() ![]() ![]() once you redo the switches heres how it should look: ![]() ![]() ![]() ![]() ![]() I hope this helps some folks out, and your welcome courtesy of myself and SCPARRISH |
seriously for how often questions about this come up it should be a sticky lol
sticky would be cool, we searched everywhere for something like this and couldnt find it
Good info, I will be putting on my 08 Harley door panels here shortly. I also have black 08 front door panels I will be selling. So whats up with the door locks ?
You have to get new pigtails
Where can I get the pigtails? Any idea on price?
Thanks! |
Those are the factory pig tails off the 06
So I have a 01 does that mean I will def need new pigtails? If so where can I find them?
I think the pigtails. Are different for the mirrors on the 04 and earlier but the windows are the same
Thanks for sharing. What did you end up doing for the locks and all the switches in the other doors?
