Door ajar and dome lights - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-20-2011, 05:52 PM Thread Starter
I have a 2003 f350 that the dome lights and door ajar lights stays on. I have tried the wd40 which did not work. I them disconnected each door switch and still cannot get the lights to turn off. Does anyone know what else I can try?
Nick Herrera is offline
post #2 of 7 Old 11-20-2011, 05:53 PM
..::ryan::..'s Avatar
Have you checked the dimmer switch to see if it is turned on? (the one next to the headlights. Make sure it isn't turn all the way up)
'05 F-350 CC LB | 35" Tires | Edge Insight CTS | Recon Smoked Cab Lights | HID's | Ranch Hand Brush Guard | Top Gun Customz 2.5" Leveling Kit w/ Bilstein Shocks | PMM EGR Delete | 2011 Tailgate w/Camera and Rear Bumper |4" MBRP Turbo Back
..::ryan::.. is offline
post #3 of 7 Old 11-20-2011, 06:01 PM Thread Starter
yes it is off
post #4 of 7 Old 01-30-2013, 04:31 AM
S690's Avatar
Ok new reply to old question, but I'm having the same problem. Anybody have any suggestions in this problem?
S690 is offline
post #5 of 7 Old 05-07-2013, 11:57 AM
FORD4LIFE
powerstrokeculver's Avatar
Quoted: 2 Post(s)
Test out all the door switchs. We had one of our fleet trucks come in for the same thing. They are wired in series and if one is bad the rest will go bad. For us the rear pass door was bad and caused the rest to test bad.
Work Horse
2006 F250 FX4
6'' Lift Donahoe Racing
Toyo ATII's 35x12.5R18 on Moto Metel Black
BPD Engine Oil Cooler
BPD FICM 53V
K&N CAI
4" Straight Pipe
XDP Coolant Filter Kit
Blue Spring mod
SCT Tuned by DP-Tuning
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
155cc or 175cc Injectors
Stage 1 or 2 Turbo
BPD Water Pump
powerstrokeculver is offline
post #6 of 7 Old 05-07-2013, 05:59 PM
squirtgun's Avatar
I went through yesterday a few sprays of PBlaster and opening and closing each door a few times did the trick.
2003 6.0L F250 4x4 Lariat
Fog Light Mod,High Idle Mod,Zoodad,Hose clamp taligate mod,08 rear bumper,Sinister EGR delete,ELC EC-1 coolant,Edge Juice,MKM(Sinister)coolant filter,HFCM drain plug upgrade,diy FICM repair(steady 48.5v now),DIY CCV mod,Torque Pro,Blue spring upgrade,Aluminum radiator,05 headlights,LED foglightd
Wish List/Things to do
Y-pipe,fuel pressure gauge,diy oil bypass(maybe centrifuge),oil pressure gauge
squirtgun is offline
post #7 of 7 Old 05-27-2013, 04:17 AM
mustangmike6996's Avatar
what exactly were you spraying? just the plunger?
mustangmike6996 is offline
