Door lights - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-06-2011, 01:11 PM Thread Starter
Door lights
So looking at the door panels on my '06 250 6.0, I see lenses for lights with a hole in the plastic where the light would mount. However, after pulling the door panel to see if the wiring exists, I can't find it...
does it exist?
Thanks in advance
mikeysfun is offline
post #2 of 14 Old 11-06-2011, 01:29 PM
mine are just plastic reflectors and not actual lights.
champc1 is offline
post #3 of 14 Old 11-06-2011, 05:23 PM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I am missing all 4 of these lenses...and yes, there are no bulbs or any sort of wiring to them. They are simply reflectors for when the doors are open and someone is approaching at night from behind.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #4 of 14 Old 11-07-2011, 09:45 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
That is one of the items that Ford stopped installing, the earlier Superdutys had the lights in them.
My 05 does not have them either!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 14 Old 11-12-2011, 12:09 PM
soccerman's Avatar
Mine don't have it either. Any one know how hard would it be to install the lights?
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #6 of 14 Old 11-12-2011, 01:31 PM
trophy_23's Avatar
My dad's 01' has lights so I imagine you could pick up a set of those from an earlier truck and just tap into your cab lights?
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #7 of 14 Old 11-13-2011, 01:19 AM
DerwoodF350's Avatar
There was a write up on it some where I stumbled across, I'll see if I can locate it in the next day or two. It didn't look too difficult.
2006 Fthreefidy FX4 Lariat, ARP studs, EGR delete, 4" TB BD X-hale exhaust(JUNK), RCD 2.5" level kit w/Bilsteins, Nitto Terra Grapplers, SCT Livewire, Liberator Y pipe, Dieselsites Coolant filter & Delo ELC, Zoodad mod, Swamps HOT FICM, Matts SRL++ & tow tunes
, CCV Mod, CompuStar 2way alarm/remote start
To do list: fluids changed out to synthetic,HID's, .
DerwoodF350 is offline
post #8 of 14 Old 11-24-2011, 06:05 PM
Frankf250's Avatar
My 07 has all 4 but not lights. Reflectors
Frankf250 is offline
post #9 of 14 Old 05-30-2013, 05:13 AM
I wanted to revive this, as I would like to do a retrofit - anyone have any insight?
Is this a possible plug and play with the purchase of some older door wiring harness?
drbelleville is offline
post #10 of 14 Old 05-30-2013, 05:25 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
yea my 99 had lights in the door and my 08 doesn't even have reflectors.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
