Interior lights??? - Ford Powerstroke Diesel Forum
Old 10-23-2011, 05:59 PM
Interior lights???
I have searched and searched and searched but cant find out what led bulbs i need to replace all of my interior lights. I would appreciate the help if any knows. I know how to do it, but want to order the bulbs just dont know which ones to order. Thanks
Old 10-23-2011, 08:55 PM
i replaced mine with blue led lights from autozone. they come in 1 inch squares of leds in various different colors. to install them i just loosened the screw that holds the stock bulb clamp in and attached the wire there. took me all of about 10 minutes and gives a great look that gets alot of compliments!
Old 10-24-2011, 06:03 AM
Suck, Squish, Bang, Blow!
It's series 578 bulbs. Go to Retro Solutions website for the best LED lights.
Click Here
Old 10-25-2011, 01:44 AM
Thanks guys, I will check them out
Old 10-25-2011, 01:46 AM
That will work for the dome light but also wanting to change the window switch's'etc on the inside.
Old 10-25-2011, 04:12 AM
Check THIS thread for a bit more info on that type of conversion.
Old 10-27-2011, 06:21 PM
Click Here
Thanks for the feedback!
Old 10-28-2011, 10:31 AM
You are more than welcome!
CAUTION: Thread Hijack!
Retro,
Will these lights produce a sufficent amount of light for roof clearance lights? I want LED, but with smoked lenses, I don't know if it will be bright or dim...
Thanks
Old 10-28-2011, 01:26 PM
Retro,
Thanks
Yes, as long as they fit in your clearance lights, which they should, those are good to use. Most folks use those or the smaller ones with only 1 LED on them, but the 5-LED are the better choice for more light!
Old 10-29-2011, 08:53 AM
Sweet! Thanks! I'll have to look into upgrading.
Hijack Over
