Seatbelt strangling me! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-29-2011, 05:27 PM Thread Starter
go_n_low's Avatar
Question Seatbelt strangling me!
I know this sounds really weird, but is the seat belt tensioner tied in any way to the accelerator?
If I'm cruising along at a normal speed the seat belt is snug like it should be but I can still lean forward/move around. If I attempt to pass someone and really push on the pedal, the belt gets so tight I can barely breathe! At first I thought it was my kids in the backseat screwing around, but today on my way to work by myself it did it again. And it won't loosen up for like 5 mins.
Is my truck possessed?
2005 F350 XLT 6.0 PSD 4x4 AUTO
WHITE CREWCAB DRW SHORT BED
ARP studs w/OEM Head Gaskets
03 Turbo w/Batmowheel
RCD EGR Delete
FPR Blue spring
6.4 Banjo Bolts
Fumoto Oil Drain Valve
Upfitter switches w/ High Idle mod
Dieselsite Coolant filter w/ ELC
Zoodad
Insight CTS w/EGT & Fuel PSI
SCT-Looney Wild
5" Straight Pipe Exhaust
08+ Tailgate
Newton 2.5" Leveling Kit
Alcoa 22.5" w/ Continental HDR
go_n_low is offline
post #2 of 9 Old 09-29-2011, 06:56 PM
0660BigHoss's Avatar
Mine only tightens under hard braking. And definitely not that tight and not for that long.
2006 F-350 SC 4x4 6.0 LongBed
W/ Banks Big Hoss Bundle and IQ Tuner
2008 Center Console
High Idle Mod
Fumoto F-111N,
BPD 6 PHASE 58V FICM
BPD EGR COOLER
BPD UPGRADED OIL COOLER
ALL ALUMINUM RADIATOR
HPOP FITTING UPGRADE
Blue Spring Mod
Rancho RS9000 XL's
No Payments Mod
Pioneer AVIC-X930BT - With Park Brake Bypass
Diesel Kleen in EVERY tank!!
0660BigHoss is offline
post #3 of 9 Old 09-29-2011, 07:01 PM
JSchuricht's Avatar
It's mechanical, no link to the peddle.
JSchuricht is offline
post #4 of 9 Old 09-29-2011, 07:03 PM
2003kingranch's Avatar
think your pulling it out to far before you buckle it. my mom does that every time she gets in my truck. i just laugh because shes squished to the seat
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #5 of 9 Old 09-30-2011, 09:01 AM Thread Starter
go_n_low's Avatar
I don't think I'm pulling it out too far. It only seems to happen on the highway. If I drive around town for an hour its fine, hop on the highway and squeezed to death. My wife thinks its funny. She says its the trucks way of telling me to slow down.
"This fat girl isn't supposed to move that quick!"
RCD EGR Delete
FPR Blue spring
6.4 Banjo Bolts
Zoodad
SCT-Looney Wild
08+ Tailgate
go_n_low is offline
post #6 of 9 Old 09-30-2011, 09:12 AM
04stroker6.0's Avatar
i would say its latching and when your on the gas you get set back in the seat a bit and it latches there when it shouldn't i would say pull the cover off and clean it and put some lube on it
04 F-350 Powerstroke, Leveling kit, 20's, Warren diesel 155's, SCT, CTS, 4" Turbo back exhaust, blue spring, Egr Delete, New oil cooler
04stroker6.0 is offline
post #7 of 9 Old 09-30-2011, 07:36 PM
JSchuricht's Avatar
I think it's time to swap drivers and passengers belts.
post #8 of 9 Old 10-01-2011, 04:54 AM
Or you can go to the Ford Dealer and get a seatbelt extension,it will give you about 6" more room.They are free,just request them. I have them on all of my cars and trucks
05harley is offline
post #9 of 9 Old 10-03-2011, 04:13 PM Thread Starter
go_n_low's Avatar
I'm not that big a guy that I think I need an extension. I can pull the belt out a lot more than I need to get around me. Just the faster I go, the tighter it squeezes.
RCD EGR Delete
FPR Blue spring
6.4 Banjo Bolts
Zoodad
SCT-Looney Wild
08+ Tailgate
go_n_low is offline
