Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Powerstroke Interior Discussion
Old 08-20-2007, 02:11 PM
lindhart lindhart is offline
Red face Ignition Switch Lock
I have an 06 F350 Lariat 4X4 LB Crew. Whenever I park with the wheels at any angle, other than straight ahead, I have the darndest time getting the key to turn in the ignition.
I turn the wheel to the left before turning the key (nothing happens) and turn it to the right before turning the key (nothing happens). I adjust the tilt of the steering wheel and, so far, I have been able to get the ignition switch to turn.
To avoid the problem, I only park with the wheels straight ahead, but something needs to be fixed.
Any ideas would be gratefully appreciated.
Old 08-20-2007, 08:05 PM
lilredpowerstroke lilredpowerstroke is offline
Are you sure you're turning the wheel hard enough?? Mine does the same thing from time to time and if I turn the wheel one way or another it will let the ignition turn.
Old 08-21-2007, 10:37 AM
DieselFord05 DieselFord05 is offline
I just kinda wobble mine back and forth when it happens to me.
Old 11-18-2007, 11:43 AM
DKR DKR is offline
<--Pro Cooler Racer
If the steering wheel locks, say if you have the wheel turned, take the key out, and the wheel returns to center (even just a little turn)...It takes a pretty good tub on the Fords to release as you turn the key.
