| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
guages A pillar
hey guys
so im looking to getting gauges for my truck. looking at glow shift due to the fact that i have nothing but glow shift guages in my drag mustang and they work very well and if i ever had a problem they were there to help. what im going with is a 60lbs boost gauge, water temp, fuel pressure. curious what you guys think? any suggestions? maybe try different guages? be honest with me guys. i wont be mad
I'll be honest. Get Auto Meter.
I have Glow shift gauges and never had problems but I would get a EGT gauge
If you're only going to be running A pillar gauges and nothing like the Edge CS or CTS I would highly recommend the following gauges in order of importance (4 pod required for these):
ECT EOT EGT Fuel Pressure The dash boost gauge works just fine, it's the others on the dash that are a complete waste of space. Personally, I'd recommend getting a Scangauge II or a CS / CTS to compliment the A-Pillar gauges. But that's just me... I like to have all of my readings in one centralized location, makes it very easy to glance over and have everything right there. If you want to stick with the A-Pillars I'd probably get a pod for above the rear view mirror too and add Tranny Temp Voltage Boost |
hey guys,
thanks for the comments and acidsniper Thanks for the info. i already have a EOT and EGT that is mounted under the dash. and my stock boost gauge isnt big enough anymore for the boost i make. i make roughly 45psi on a ATS 4000 turbo. And currently i have a superchip programmer for my truck. i plan on goign with the cts but as of right now the superchip does fine. i just want to be able to monitor everything since i have bigger injectors and more boost. |
If I were you, I'd move that EOT gauge NEXT to the ECT gauge. I've got a quad pillar:
ECT EOT Trans Fuel Pressure I've got an EGT on the column. But you'll definitely want the EOT and ECT together. |
