| 6.0L Powerstroke Interior Discussion This Section is for interior discussion |
Fog light switch?
I have fog lights, but I don't see where there is a switch for them. I have an empty spot next to my brake control. I've seen on here that there should be a switch panel right there. Is that the only place it could be, and how do I know which wires are for the fog lights?
You should be able to turn the lights on all the way and then pull the knob.
Sweet, that worked... The ignition has to be on for the fog lights to come on though... Thank a bunch for your help man!!!
NP - That's what we're here for.
I just hope I can help others eventually... Can you tell me what those switches are for next to the tow brakes? I don't have the switch panel, it just a hole on the left and the tow brake thing on the right!!! I was curious what they're for...
I believe they are called upfitter switches. I think they are not hooked up to stuff so you can use them as you want. You can probably find more about them by entering "upfitter switches" in the Google custom search box in the upper left of the page under the PowerStroke.org logo.
Oh, ok!!! I will check it out... Thanks again!
my upfitter switch wires were orange with different color stripes and they were behind the driverside fuse box under the dash, i didnt get fog lights from the factory but i added them and wired them to aux 4 switch that way i can run them with high beams. if you want to run your fog lights while on high beams there is a "fog light mod" type it in on the very helpful search feature in the top left. i believe all ya need is a jumper wire. a month or so of searching on here will have you giving advice to new comers in no time.
oh and if ya want a nice upgrade that is well worth the money and its a safe upgrade, straight pipe turbo back exhaust sounds awesome on these trucks. but make sure u get some kind of monitor to watch temps. |
Thanks man, I will have to check that out!!!
